Loose Seat
Old Aug 13, 2012 | 05:39 AM
Brother F's Avatar
Brother F
Loose Seat
The seat in my '54 has too much fore and aft play. It looks to me that it's primarily on the passenger side. I can push the seat back and forth about an eighth of in inch. That doesn't sound like much but if feels like much more to the passenger. I have tightened all of the bolts that I can see without any improvement. Is there a fix for this? I've searched here and looked through my service manual but I haven't found a solution. Any help would be much appreciated. Thanks
Steve
Old Aug 13, 2012 | 08:12 AM
56panelford's Avatar
56panelford
I no longer have an original bench seat and can't remember the mechanics of them but was wondering if there was a spring that has too much slack in it. I'll check to see if there is anything in the manual and get back to you. You might want to check if some of the bolt holes have worn out to an oval shape from use over the years.
Edit; just checked the manual and there is nothing that would help you.
Old Aug 13, 2012 | 09:32 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Is the whole seat frame moving, or is the seat track on that side unlocked and sliding?
Old Aug 13, 2012 | 10:18 AM
Brother F's Avatar
Brother F
Thanks 56PF.
The seat track is sliding. The frame is tight to the track but the passenger side track moves. It seems to hit a stop but there is just too much play.
Old Aug 14, 2012 | 09:33 AM
petemcl's Avatar
petemcl
Steve
I don't know if your '54 is a similar design to my '50 but I found that changing the angle of the seat tracks (move the front of the right track left or right in relation to rear) and move one track fore or aft in relation to the other track (my mounting holes are slotted) changed how hard or easy the seat moved.
Old Aug 16, 2012 | 05:40 AM
Brother F's Avatar
Brother F
Thanks Pete. I've been bolting up my restored bed so I haven't worked on the seat. I'll take a look at this today. A quick glance didn't show a slotted hole but there is a washer under the bolt. I pull that bolt out and check today.
AGrayson84
29
Jun 27, 2019 10:53 AM
lakahahahman
Bronco II
Dec 20, 2005 08:51 AM
65kcoupe
1978 - 1996 Big Bronco
Jul 24, 2004 05:00 PM
bronco351
Dec 12, 2003 08:41 AM
