TC lock
Old Aug 15, 2012 | 07:31 AM
  #46
oldbird1965's Avatar
oldbird1965
I've never looked at 'EX.BACK PRESS', I'll have to take a look. Last winter though I did clean the tube.
Old Aug 15, 2012 | 07:44 AM
  #47
oldbird1965
I've been thinking about the flexplate, would a high torque starter and powerful XS power batteries 'hurt' the flexplate? I mean this setup spins that motor over really fast!!
Old Aug 15, 2012 | 09:26 AM
  #48
Talyn's Avatar
Talyn
Unless the bolts were loose to the crank, or it was a **** flexplate, I don't see where there would be an issue.
Old Aug 15, 2012 | 10:44 AM
  #49
Hussler's Avatar
Hussler
It's not a very exciting parameter to watch. If you have the EBPV unplugged then you won't see much change in the numbers, maybe 3 - 4 PSI at the most. It's interesting to watch in winter when the PCM is using the valve for rapid warmup. PCM likes to keep the back pressure between 20 - 30 PSI but because it's a slow moving valve it's easy to go over 30, then PCM opens EBPV a bit to compensate. Just an interesting parameter to watch and some piece of mind why the rig is doing what it is doing ...
Old Aug 15, 2012 | 12:44 PM
  #50
Talyn's Avatar
Talyn
Wrong sensor bro.
Were talking about the sensor on the front of the HPOP.
Old Aug 15, 2012 | 03:00 PM
  #51
DIYMechanic's Avatar
DIYMechanic
Originally Posted by Talyn
Wrong sensor bro.
No, Jim is talking about the right one. That's the EBPS. It has a tube that feeds down into the passenger side manifold.
Old Aug 15, 2012 | 03:01 PM
  #52
Hussler's Avatar
Hussler
Wrong sensor bro.
That's what I'm referring to, exhaust back pressure sensor.
Old Aug 15, 2012 | 03:18 PM
  #53
Talyn's Avatar
Talyn
Oh crap, I'm sorry. Your wording led me to believe you were saying it was the EBPV.
Old Aug 15, 2012 | 08:59 PM
  #54
oldbird1965
Running around light today, maybe 20 miles, I was reading 14 to 18 depending on load.
Old Aug 16, 2012 | 07:02 AM
  #55
DIYMechanic
I would guess that's about normal. It should read close to a 1:1 ratio to your boost pressures.
Old Aug 16, 2012 | 08:15 AM
  #56
Talyn's Avatar
Talyn
I never see mine over 14 and never under 10.
I wonder though, if you are seeing higher backpressure numbers what that could help diagnose.
Old Aug 16, 2012 | 08:25 AM
  #57
DIYMechanic
I wouldn't worry about the back pressure numbers as long as they correlate to about a 1:1 ration on the boost pressure. The more fuel you dump to it, the more boost and back pressure you can expect to see.
Old Aug 16, 2012 | 09:30 AM
  #58
Talyn's Avatar
Talyn
I don't think you'll see a 1:1 ratio on it is what I'm getting at.
LMPLLC
104
Jan 7, 2014 05:31 PM
'94IDITurbo7.3
55
Jul 30, 2012 07:35 PM
diesel-fitter-bum01
Mar 11, 2012 10:55 PM
JethroF250
Dec 23, 2009 11:35 PM
ron's power stroke
35
Apr 29, 2007 10:17 PM
