whoosh
Old Aug 10, 2012 | 10:25 PM
lartross's Avatar
lartross
whoosh
Will someone tell me if the whoosh I hear when it upshifts is the waste gate opening? And if it's normal? Sounds like a big rig air system venting the air compressor...except only when the engine is loaded up.
Old Aug 10, 2012 | 10:26 PM
lartross's Avatar
lartross
I posted this in eh 94-97 forum by mistake and kinda' got laughed out of there, I guess.
Old Aug 10, 2012 | 10:54 PM
CSIPSD's Avatar
CSIPSD
Its not the wastegate. You will never hear the wastegate on a stock 7.3 turbo.
Its turbo stall due to the engine RPM's changing/dropping quickly. There is no where for the air to go so it rushes out the intake.
Normal, and mostly not harmful.
Old Aug 11, 2012 | 12:09 AM
fordpride's Avatar
fordpride
We wouldn't laugh you out of the OBS section. Your more than welcome to drop in anytime you want.
I answered your question in that thread
Old Aug 11, 2012 | 05:52 AM
lartross's Avatar
lartross
Thanks Mike and Joe. I moved to this forum before I read your answer, MIke. Thank you. So, Joe, is this what people use the ww to try and cure? You did say it mostly doesn't hurt anything...what does that mean? It's gotta be whooshing out the air filter, right? Is it hard on the turbo? The intake system?
And I've read and read and I can't really find anywhere that boost has much effect on power. Why do people try to increase boost by messing with the waste gate?
Old Aug 11, 2012 | 07:48 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
My guess is, you just installed the 6637. Lots of people like the woosh after the shift. Enjoy and drive, nothing will get hurt.
Old Aug 11, 2012 | 07:58 AM
Tugly's Avatar
Tugly
Ah... I might know this one (but get more input). The turbo is just more air, which is not power by itself. The increased air flow assists in cooling the exhaust and helps the atomized fuel to "flash" burn. Take off the turbo and you have a smokey dog with a hot exhaust (fuel burns slower and incompletely). Bump the turbo up to a bigger one with a tuner to add more fuel (more air facilitates more fuel) and you've got a clean screamer that stays cool.
Shields up... ready for retort.
Old Aug 11, 2012 | 09:35 AM
lartross's Avatar
lartross
Well, thanks Rich. That makes sense to me . And Rick, yes, I first started noticing the whoosh after the 6637 install. So, I guess I'm good to go until I get my buckzooka reloaded!?
Old Aug 11, 2012 | 12:05 PM
pin8246's Avatar
pin8246
Your fine with the sound. All my turbo cars have had it, and both of my trucks do. The only difference between the cars and these trucks is that on the cars I could use a blow off valve that releases the air instead of coming back through the filter. Havent see anyone on here stating if this is possible on trucks or not.
Old Aug 11, 2012 | 12:35 PM
trekbasso's Avatar
trekbasso
The ww (wicked wheel) is a fix for turbo surge, which is different from the whoosh after shifts you are hearing. Boost DOES affect power. And you are right, get that "buckzooka" loaded. Your adventure is just starting.
Old Aug 11, 2012 | 12:48 PM
Tailgate77478's Avatar
Tailgate77478
Bingo. An open intake makes that a very noticeable sound. Takes a while to get used to it!
Old Aug 11, 2012 | 03:25 PM
lartross's Avatar
lartross
Thanks for all the information. I do like the whoosh! Sounds kinda' like a big rig...
FlatHat Ranch
Dec 6, 2013 07:38 PM
gunner 70
17
Nov 5, 2007 03:16 PM
John Kiernan
Nov 14, 2006 10:07 AM
ac1108
Nov 28, 2004 12:22 PM
fisher_of_man
Oct 17, 2003 12:08 AM
