1978 - 1996 Big Bronco
Engine Surges
Old Aug 10, 2012 | 09:52 AM
73-79owner's Avatar
73-79owner
Engine Surges
Hey Guys just got my first Bronco. It is a 94 with a 5.0 and E4od. I was driving it recently and notices sometimes while at speed between 30 and 45 the engine feels like it is jumping in and out of overdrive. Also some times it will rev up from 1500 rpms to 3000 when cruising and not go anywhere then it immediatly fixes it self. There is no slam from the trans just the rpms reving up. All fluids are new and are at good levels.
Also noticed it usually only does it during the first drive of the day. If I stop for a while then go out and drive again it does not do it. I don't drive it every day just about once a week.
Any help would be awesome. Thanks.
Old Aug 10, 2012 | 10:12 AM
Kemicalburns's Avatar
Kemicalburns
Pull codes, this should be your first step. once we have this info we can proceed. search as the process has been covered a bunch.
this will keep you from throwing parts at it.
i also have that year bronco except mine has the 5.8
Old Aug 10, 2012 | 11:38 AM
greystreak92's Avatar
greystreak92
Ditto to everything Kem already said. One question... what size tires are you running?
Old Aug 21, 2012 | 02:42 PM
73-79owner's Avatar
73-79owner
Sorry it took a while to get back to you guys I have been out of town. I am running 32/11.50/15 for tires. I have not been able to get codes read but am working on it.
Old Aug 21, 2012 | 03:41 PM
Kemicalburns
swing by the autoparts store, they will generally pull codes for you.
sgted1974
13
Dec 31, 2014 09:37 AM
kellie
Dec 29, 2010 02:09 AM
fkaster01
15
Mar 30, 2009 09:23 PM
82MustangGT
Dec 22, 2007 02:16 PM
bronco351
Jul 16, 2003 04:02 PM
