1994 Bronco Xlt
5.8 w/e4od trans 127,000 miles
3.55 gears
33x12.50r15
3 inch lift
Today the truck started to vibrate on decell put it in neutral goes away only does it when its in gear trans does not slip shifts good all fliuds good check u joint all are good i need some help on this one
well its involving the downshifting electronics most likely. Ther can be dirt or something is starting to fail or wear out. See if there are any transmission codes being thrown.
i would do a couple test runs, try it out of OD, if you can try it in a lower gear as well and see if it does the same thing. I would check the rear end and work forward from there. Does this happen with decel only or decel and brakes applied?
its only on decaell if i ride the brake and keep the rpms up a little it dont do it i've tried no od and lower gears it still does it i will be changing the drive shaft tommorow after work thank guys for the input
Well got my new drive shaft for the Bronco today put it in backed out of the drive put in drive bang blew the rear end so SANTA if your read this i would a new rear axle assembly w 3.55 gears for a 94 bronco w/ abs
hope you all find this funny because i want to put a stick of dynamite in the gas tank and blow the truck sky high
so if any one knows where i can get a rear assembly in michigan let me know
1994 Bronco
4 inch lift
33x12.50 r15 mud terraind
351
e4od trans
well finally got some time to look at the truck pull the rear cover and noticed the pinion gear had dug into the trac lox carrier rotated the wheel a little the whole track lox carrier is split, so now i have to wait till wed to try to find a rear end but hopefuly i can find one priced right so far all i have found is a couple from cherry auto parts for 500-700 not gonna pay that for a junk yard rear
