Spark Plug Gap Confusion
Old Aug 10, 2012 | 06:18 AM
Jumpdummy's Avatar
Jumpdummy
My truck has a 302 that came out of a 1983 Thunderbird. Everything I've read on here says .044 gap on the plugs but the parts store told me .05. BTW I did buy Motorcraft plugs Which gap should I set?
Thanks
Old Aug 10, 2012 | 06:37 AM
critterf1's Avatar
critterf1
Stay at .044.
Old Aug 10, 2012 | 07:28 AM
Jumpdummy's Avatar
Jumpdummy
Thanks....
Old Aug 10, 2012 | 07:37 AM
Grubbworm's Avatar
Grubbworm
I would agree about the .044. The gap should also be listed on a sticker under the hood, probably on the vacuum diagram label.
Old Aug 10, 2012 | 07:52 AM
Jumpdummy's Avatar
Jumpdummy
It is listed on the sticker but the truck originally had a 232 V6. Not very common. Wish I had saved the engine in case I wanted to put it back original, although that is unlikely. Couldn't pass my Grandma with that thing.
Old Aug 10, 2012 | 12:06 PM
Grubbworm's Avatar
Grubbworm
Oops, sorry, I didn't know.
Old Aug 10, 2012 | 01:47 PM
Jumpdummy's Avatar
Jumpdummy
Grubbworm I appreciate all the help I can get. I realize you are not a mind reader
Old Aug 10, 2012 | 02:07 PM
Grubbworm's Avatar
Grubbworm
No problem.
Old Aug 10, 2012 | 02:46 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It really depended on engine calibration and the plugs used. Why Grubbworm mentioned the Lable. It would tell you the exact gap for your engine. (If you had the correct lable etc)
But I agree, .044 is the most comon, with breakerless ignitions so use that.
Old Aug 10, 2012 | 03:15 PM
Anafiel's Avatar
Anafiel
I use .055 as I have a HEI dist and a high voltage coil, and 9mm wires. I can easily jump the gap, and it makes for better combustion and MPG.
Old Aug 10, 2012 | 04:49 PM
1983F1503004x4's Avatar
1983F1503004x4
0.042 here. That's what it calls for with my 83 300-6. Obviously yours is a 302. I don't imagine that the gaps will be that different, being all of these use the same ignition system.
Old Aug 10, 2012 | 05:39 PM
81-F-150-Explorer
My 1981 300-6 calls for .044, but it has a service range of .042-.046
Like I said it depends on engine calibration.
Old Aug 11, 2012 | 01:33 AM
Trashyvixxen's Avatar
Trashyvixxen
For the 83 ford Thunderbird with a 302 , using motorcraft spark plugs you do need to gap to .050
Old Aug 13, 2012 | 10:54 AM
Jumpdummy's Avatar
Jumpdummy
I changed the plugs, plug wires, distributor cap and rotor this weekend and the truck still doesn't run like it should. I did set the gap at .046. The plugs that came out were set at .050. Might need to try them at .050 and see if that helps. Bought a timing light and can't see the damper from the top. Any ideas on that?
sessland
Jan 23, 2015 11:33 AM
copperjohnc
Sep 28, 2011 11:02 PM
Owl
Apr 21, 2007 11:25 PM
Fordbyford
1978 - 1996 Big Bronco
23
Mar 29, 2005 08:09 PM
