1978 - 1996 Big Bronco
Spark plug gap anyone???
Old Feb 17, 2005 | 02:00 AM
Fordbyford's Avatar
Fordbyford
Question Spark plug gap anyone???
I'm about todo a tune-up on my 1996For bronco XLT 351W and was woundering what the spark plug gap is,I woul know what it is if the owner before me didnt rip of the spec chart under the hood to paint the inside of the hood but any way was also woundering what the best (Preformance wise) spark plugs and wires would be thanks
Old Feb 17, 2005 | 03:34 AM
muckypaws's Avatar
muckypaws
on mine its 44 thou or 1.1mm in French which is a '92 302. Seems huge to me compared to all the other vehicles I have had. Has anyone found a deviation from the book at works better?
Old Feb 17, 2005 | 08:31 AM
94 XLT White/ Silver 302's Avatar
your spark plug gap should be .052-.056 I set my plugs at 0.55 , I use standard Autolite spark plugs with Ford Motorsport 9mm. wires you can buy the wires at Summit Racing for $39.95 in blue
Old Feb 17, 2005 | 08:54 AM
muckypaws's Avatar
muckypaws
That gap is getting bigger and bigger! why so large on a Bronco?
Old Feb 17, 2005 | 09:05 AM
jimandmandy's Avatar
jimandmandy
A bigger gap means a bigger spark. If the system can produce sufficient voltage to jumb that gap without misfire, you get lower emissions, better economy and more power. As a side note, multi-ground-electrode plugs dont give more sparks, just theoretically last longer.
Jim
Old Feb 17, 2005 | 09:08 AM
muckypaws's Avatar
muckypaws
hmm if it wasn't such a bitch to get to them on my Bronco I'd try opening them up a bit and see if it improves my economy - at $6.53/gal I need all I the mpg I can get ;-)
Old Feb 17, 2005 | 09:41 AM
Kemicalburns's Avatar
Kemicalburns
that is way to much gap for a stock ignition. .44 is the correct gap for your plugs. only if you were running an msd coil and or 6Abox would you gap your plugs that much.
Old Mar 22, 2005 | 09:42 AM
f1001978's Avatar
f1001978
The fatory spec for the TFI system is .054".
Old Mar 22, 2005 | 09:46 AM
muckypaws's Avatar
muckypaws
can you cite your source? My haynes and chiltons book both say 44 thou.
Old Mar 22, 2005 | 12:42 PM
gimmeice3's Avatar
gimmeice3
Wink
just did a rebuild and specs in the manuel i was using said .42 - .46 so i put it at .44 it should also tell you specs on the sticker on the air cleaner with the vacuum diagram if you have one
Old Mar 22, 2005 | 04:54 PM
93BigBlackBronco's Avatar
93BigBlackBronco
Plug gap should be listed on the Emission diagram sticker under the hood. Usually on the radiator support. Should have engine size listed and type of emissions installed at the fatory.
Old Mar 22, 2005 | 05:47 PM
My emissions label under the hood says .052-.056 for a 94 with a 302 engine.
Old Mar 22, 2005 | 06:25 PM
iagainsti's Avatar
iagainsti
One of the advertisers @ bottom of page lists all plugs for the 5.8 @ .044 and the 5.0 irridium and platinum @ .054 and .044 for gold ?
Old Mar 22, 2005 | 08:11 PM
BigRedBronc's Avatar
BigRedBronc
I also have a 1996 5.0, the following refers
Chilton's Manual (Manual #26664) Page 1-30 says plug gap 0.044
Haynes Manual (Manual #36058) Page 1-3 says plug gap 0.044
Both manuals have a note that says to refer to the Emission Control Label in the engine compartment, and to use the values on the label if different from the manual.
Emission Control Label in engine compartment says spark plug gap is .052-.056
Are we all thoroughly confused now?
Old Mar 29, 2005 | 01:08 AM
muckypaws's Avatar
muckypaws
had a look on the sticker at the weekend - its on the bottom of the hood on my truck so you have to read it sort of upside down. Anyhow, it says .042-0.046.
