Speedo help please
Old Aug 25, 2012 | 11:16 PM
  #31
rangergirl94's Avatar
rangergirl94
Ok looks like I wont have a speedo
Old Aug 26, 2012 | 06:50 AM
  #32
subford's Avatar
subford
Why not?
I would guess you have a open wire between the rear end and the plug going into the PSOM on the back of the cluster. Just ohm out these two wires.
One of the plugs may have a pin in the wrong hole.
Is the PSOM plug even plugged into the back of the cluster?
Old Aug 26, 2012 | 09:50 PM
  #33
rangergirl94
Yes I double checked the cluster plugs ill have to trace those vss wires
Old Aug 26, 2012 | 11:03 PM
  #34
Truckin Bob's Avatar
Truckin Bob
Still no answer from rangergirl94 regarding power at fuse #18 in the cab while the truck is running.
If no power at fuse #18 and fuse is good, check engine compartment fuse # J and power at fuse # J.
Other than that, it could be a faulty ignition switch not powering the RABS and PSOM circuits.
I'm thinking the ribbon cable on the back of the PSOM is damaged or not inserted correctly/not fully seated, or one of the very fine wire pins in the female connector at the PSOM is bent or missing , That IS a pretty difficult area to work in.
Bob
Old Sep 5, 2012 | 12:29 PM
  #35
rangergirl94
No power at 18 ill check j
Old Sep 5, 2012 | 12:34 PM
  #36
Truckin Bob
There you go. !!!!!!!!!
That is most likely where your problem lies !!!!
Good job !!!!!
Bob
Old Sep 5, 2012 | 04:07 PM
  #37
rangergirl94
Is there a diagram for the under hood fuse box I dont see j
Old Sep 5, 2012 | 06:10 PM
  #38
subford's Avatar
subford
Here is a diagram of the 1992-1995 Engine compartment fuse/relay box.
If you meant how the Fuse/relay box is wired here is a diagram for that:
Old Sep 15, 2012 | 12:00 AM
  #39
2001FUMMINS250's Avatar
2001FUMMINS250
Cummins conversion now speedo doesn't work
Hey guys, i read the thread and you might be able to help me out. I have a cummins swap in my 2001 f250 the speedo was supposively working before the swap and now it's not. The indicator is over to 90 and when I drive it floats back to 70-75. I changed out the VSS sensor on the rear end. Didn't fix it. But my odometer works fine. Can you give some advice? I'm gonna check fuses right now. Thanks in advance!
Old Sep 15, 2012 | 12:30 AM
  #40
Puddy's Avatar
Puddy
these fuese are for pre-97 f-series, you sould ask over in the 97-03 fourm, probably get better answers there.
Old Sep 15, 2012 | 12:34 AM
  #41
2001FUMMINS250
Thanks. I'll do that.
bradphx
Sep 25, 2016 02:37 PM
greentruck72
Feb 9, 2016 03:28 PM
Aussie BrianB
Australia Chapter
41
Jul 27, 2013 09:53 PM
Aquik72
Jun 7, 2010 09:25 AM
