ttb lift
Old Sep 14, 2012 | 06:11 PM
jhendry's Avatar
jhendry
ttb lift
Anybody lift there 92-96 truck without drop brakets and driveablity isues with lift I wanted to go 6in
Old Sep 14, 2012 | 06:20 PM
garthneddy's Avatar
garthneddy
Thats an impossibility unless your swapping in a solid axle.
Old Sep 14, 2012 | 06:21 PM
jhendry's Avatar
jhendry
Any pics of lifts
Old Sep 14, 2012 | 06:23 PM
jhendry's Avatar
jhendry
No not impossible I've seen it before I was wondering if anyone out there has done it
Old Sep 14, 2012 | 06:32 PM
garthneddy's Avatar
garthneddy
Yes, 100% impossible. I can guarantee you have never seen any ttb lifted 6" with the factory drop brackets.
Old Sep 14, 2012 | 07:16 PM
2007F150FX4's Avatar
2007F150FX4
You can get 4" of lift with cut and turned beams using the stock pivot brackets. Its a common upgrade to TTB trucks in the desert scene.
Never seen anything higher unless it is 2wd.
Old Sep 14, 2012 | 07:22 PM
minnesotafisherman's Avatar
minnesotafisherman
It is not impossible if you cut and turn the TTB arms.
OTHERWISE, yes it is impossible. The highest you can lift the front ends on these trucks without any drop brackets is 2 inches.
EDIT: 2007F150FX4 beat me to it!
Old Sep 14, 2012 | 08:41 PM
jhendry's Avatar
jhendry
Alright when I do it ill post a pic because I've seen it and 6in drop brakets and 8in coils on another truck
Old Sep 14, 2012 | 09:11 PM
Diesel_Brad's Avatar
Diesel_Brad
but that is NOT what you said in your original post
Old Sep 15, 2012 | 02:46 AM
garthneddy's Avatar
garthneddy
I was assuming that he meant with stock beams. Please do take pictures. I'm curious how you will piece this lift together considering there are no 8" ttb coils that are being produced.
Old Sep 15, 2012 | 03:25 AM
khadma's Avatar
khadma
Carpenter Local 745
Older prerunners used to cut and rotate TTBs
http://www.pirate4x4.com/forum/attac...1&d=1079503377
Skyjacker makes 8 inch suspension systems for TTB trucks.
old_lynrd
Feb 20, 2011 08:09 PM
fordinmudd
Offroad & 4x4
Aug 16, 2006 11:08 PM
jimbob21rc
Offroad & 4x4
Jun 7, 2005 10:38 PM
