Steering Wheel Click
Old Aug 8, 2012 | 02:31 PM
xjcamaro89's Avatar
xjcamaro89
Hey guys, long time no problems!
Got my 2007 XLT Screw here, love this truck, not one problem with it since i got it. but i have started to hear and feel a noise.
Let me know if anyone else has come across this. I have a click sound and slight click feel in my steering wheel. This happens when im sitting still with the wheel straight, and i just slightly rock the steering wheel back and forth. If i turn the wheel a full turn left or right then rock the steering wheel back and forth i dont get the sound or feeling. Also if im cruising down the road and rock the wheel back and forth slightly i dont get it.
This is something between the steering wheel and the firewall. I checked all steering shafts and all suspension from the firewall down to the wheels. So that at least make me feel better that im not dealing with one of those steering shafts or a suspension repair. Im not too worred about, but let me know what you guys think.
Jason
Old Aug 8, 2012 | 08:52 PM
ptmares's Avatar
ptmares
Hopefully someone else has a fix for this problem.
I have a 2007 Expedition EL that does the same exact thing to the T.
I have 102,500 on mine. Not sure if the mileage has anything to do with the problem.
Old Aug 8, 2012 | 08:56 PM
xjcamaro89's Avatar
xjcamaro89
Mine only has 52K miles. I think there is a shaft in the steering column that has a joint in it. Might be that. I haven't looked under the dash yet. Too much stuff going on.
Old Aug 20, 2012 | 02:11 PM
xjcamaro89's Avatar
xjcamaro89
Anyone have any ideas?
Old Aug 20, 2012 | 04:05 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Yes there is it needs lube from time to time WD40 will fix it if it looks rusty.
Old Aug 21, 2012 | 07:56 AM
xjcamaro89's Avatar
xjcamaro89
The shaft in the steering column in the cab? Ive had to deal with the shaft in the engine compartment but not the one in the column.
Whats the best way to get to it, and is there a easy way to remove the plastic around the column.
Thanks
Old Aug 21, 2012 | 03:08 PM
2004 xlt 5.4
Thanks
Ups did not know there was one under dash
Old Aug 21, 2012 | 03:39 PM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
Alldatadiy.com has symptom related information as well as repair information. Good luck with your search for the resolution!!
Firefighter 1406
Dec 28, 2016 08:34 AM
atomrat
Jul 13, 2014 06:56 PM
LaredoF350
Jan 4, 2008 11:55 AM
