Transmission skips
Old Aug 8, 2012 | 08:21 AM
magivens's Avatar
magivens
Transmission skips
My transmission skips (not bad, but irritating) until the fluid is at normal operating temperature. I had the PCM re-flashed, but still the same problem. Any ideas?
2006, F-350, 6.0. No upgrades
Mark Givens
Old Aug 8, 2012 | 10:30 AM
cartmanea's Avatar
cartmanea
What do you mean by "skips"? Did you mean "slips"? How many miles, and what is the transmission service history? Any mods?
Old Aug 8, 2012 | 10:41 AM
magivens's Avatar
magivens
Yes, it slips until warmed up. 120k on mileage and no mods. Service history is good, proper fluid and filter changes.
Old Aug 8, 2012 | 10:44 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
What fluid have you used in the tranny? Name brand and type. SP or LV? Changed the external trans filter? Last mileage changed?
Old Aug 8, 2012 | 10:51 AM
magivens's Avatar
magivens
Amsoil synthetic, I think SP. I couldn't locate an external filter. Ideas of where it is?
Old Aug 8, 2012 | 10:53 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Up under pass side of front bumper..... don't hand wrench on it....use a impact wrench or else you'll bend the pipe above it.
Old Aug 8, 2012 | 11:17 AM
sammy77's Avatar
sammy77
If you can't locate that filter then chances are it hasn't been changed. So, we can throw out that statement..lol
Anyway, as stated you can find that filter passenger side underneath the truck, look just before the radiator. Not sure on the Amsoil Trans fluid either.
Old Aug 8, 2012 | 11:46 AM
magivens's Avatar
magivens
Thanks, will let you know.
Old Aug 8, 2012 | 01:20 PM
69cj's Avatar
69cj
Amsoil is not an SP or LV type tranny fluid. If it were my truck I'd take it to a Ford dealer and have the tranny hot flushed with the proper fluid and also get that ext. filter changed. Every 30,000 miles is the recommended interval.
Old Aug 8, 2012 | 01:21 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Careful when you drop it...the canister will be full of fluid.
Old Aug 8, 2012 | 02:16 PM
69cj's Avatar
69cj
8 ounces to be exact.
Old Aug 8, 2012 | 06:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think we have found both of the causes.
Old Aug 9, 2012 | 12:26 AM
cartmanea's Avatar
cartmanea
Amsoil has a low viscosity fluid that meets the SP/LV spec. My dad has had it in his Torqshift for about 25k now and tows very heavy pretty often.
Old Aug 9, 2012 | 07:55 AM
magivens's Avatar
magivens
Gents, AMSOIL sells a synthetic product specifically for these transmissions. AMSOIL - Synthetic Fuel Efficient Automatic Transmission Fluid (ATL)
Old Aug 9, 2012 | 08:10 AM
69cj's Avatar
69cj
Use what your comfy with, it's your trucks, I've had no problems with SP or LV and I still have 3 1/2 years esp warranty left. I'll stick with what got me this far and is recommended.
brychar
6.4L Power Stroke Diesel
56
Jul 16, 2016 12:58 AM
cyclone3565
Jun 1, 2011 11:24 PM
JP Hobbit
1983 - 2012 Ranger & B-Series
Jan 25, 2010 09:10 AM
dirty ernie
Jun 14, 2008 06:54 PM
BroncoBlaze
1978 - 1996 Big Bronco
Mar 27, 2003 11:31 PM
