tps sensor
Old Aug 7, 2012 | 05:56 AM
nintey4f150's Avatar
nintey4f150
tps sensor
ok so i have my 94 f150.. 351 trickflow stage 1 cam ported gt40 heads trickflow r series upper n lower.. i have a 75mm throttle body.. i went to change the tps sensor the other day and the new one seems to be tighter then i think it should be so when i started it up and hit the gas it seems to make the throttle stick a lil...i gave it gas from under the hood and it doesnt seem to spring back like it should.. so i put the old one back on and it doesnt do it as bad but i have noticed the wear on the old one.. yes i bought the right one.. i think i just have a cheap throttle body as it has no name or part number at all... it was given to me when i bought the upper and lower intake... any ideas?
Old Aug 7, 2012 | 06:31 AM
nintey4f150
it just doesnt seem to seat properly
Old Aug 7, 2012 | 06:35 AM
XLT89F350cc's Avatar
XLT89F350cc
try reaming the holes in the tps a little an re-adjust the throttle blades to where theyre just slightly open when its fully closed.
is the tps voltage around .990 closed ?
Old Aug 7, 2012 | 07:50 AM
rla2005's Avatar
rla2005
There is absolutely no reason to ask that question or attempt to adjust the TPS to a specific voltage on these trucks. Anything between 0.6 -1.0VDC @closed throttle is fine. If the output is in between those values, leave it alone.
On another note many of the aftermarket sensors, including the TPS, are very suspect quality. Did the OP purchase a Ford/Motorcraft TPS? If not that is probably the cause of the throttle sticking.
Old Aug 7, 2012 | 10:29 AM
XLT89F350cc
rla, i know you know alot more then i do. what happened to my truck, the throttle body came in new with the blades closed to much and were slightly binding. i had to move the screw an re-set the tps. maybe op has the same problem ?
Old Aug 7, 2012 | 01:41 PM
rla2005's Avatar
rla2005
That is a very good point and observation. The throttle blades need to be just slightly open to prevent binding. If the blades are not binding without the TPS, then it may be a moot point.
Regardless, if you need to reset the throttle stop screw there should be no reason to adjust the TPS as long as it is in between the values listed above.
xc4jokestomper
Sep 17, 2011 08:15 AM
xc4jokestomper
Aug 28, 2010 12:55 PM
drunkenrich
Jun 11, 2010 10:45 AM
frankyford
Nov 23, 2007 10:58 PM
gdoggy
1983 - 2012 Ranger & B-Series
Jun 19, 2003 09:48 PM
