Soot count
Old Aug 27, 2012 | 10:39 PM
  #46
madhatr02's Avatar
madhatr02
Originally Posted by kper05
If your gear display remains active between starts, you have the 400/800.
This was the first letter I received in 2010 and was classed under customer improvement or something like that.
The NOx fix is the only recall (if you want to call it that) that I'm aware of.
This is where I received two notifications.
Most of the other fixes were for those of us who had misbehaving transmissions.
It took Ford awhile to get the issues worked out (almost two years actually).
If yours is flawless, no need fixing som display remains activeething that isn't broken.
The current NOx fix does have an expiration but I think it's sometime next year.
What do you mean gear display stays active? Bought truck in March 11 which is after the 400/800 flash was put out and salesmen mentioned those numbers so pretty sure mine does. Guess I could just call and ask.
Old Aug 28, 2012 | 07:02 AM
  #47
720Deere's Avatar
720Deere
With a March 11 build you are definitely 400/800. They started coming straight from the factory that way in September 2010.
Old Aug 28, 2012 | 08:10 AM
  #48
Painted Horse's Avatar
Painted Horse
If your gear numbers are displayed ( press the +/- on your drive selection handle) and they stay displayed after you turn the truck off and restart the truck, Then you know you have the 400/800 reflash. But as mentioned, any truck built after Sept 2010 already has this from the factory.
Old Sep 1, 2012 | 08:14 PM
  #49
Dim Sum's Avatar
Dim Sum
Man I noticed this on my TSB updated truck today. 90 miles after a regen on the same tank I find myself regening again with very few city miles on the tank.
I've never seen a regen twice in the same half tank of diesel fuel. I'm not impressed. This truck was doing so well before the update.
I don't know how to complain about this to the dealer. No codes...so you know they are just going to tell me to pound sand.
Fefanatic
Jul 24, 2021 06:01 PM
dpilot83
Jun 10, 2016 10:21 AM
srqdiesel chef
Sep 23, 2011 01:17 PM
SandR
6.4L Power Stroke Diesel
Jun 23, 2011 09:08 PM
rdenis
6.7L Power Stroke Diesel
32
Feb 20, 2011 12:31 PM
