any advantage to removing the Catalytic converter
^^^---lol, that sums it up pretty good right there. The cats on our trucks are pretty "high flow" units, unlike the the seriously restrictive cats from "back in the day". Engine management is set up for it also, so any big gains would be at higher RPM's AND with tunes to take advantage of any increase in airflow. Some have posted there's a slight decrease in bottom end power "off the line". Of course if you were building a competition truck with an aftermarket turbo, bigger injectors, and custom tunes you would want it off there quick.
100* seems like a good thing to me. Is this a relatively insignificant benefit, as pertaining to benefit vs gain with regards to legal exposure?
If you have an aftermarket exhaust (which I imagine you do) 100* isn't much. I have 4 inch turbo back MBRP with CAT in, and pulled a long grade with a 10k fiver in 110* ambient temp and barely broke 1000* egt pre-turbo. The only time I have ever seen my EGT's hit 1300 was "testing the limits" of Matt's hybrid race tune, with WOT. In my truck it is virtually impossible to get the EGT's too hot. I would say to have the cat put back in, just for legal reasons. And it does supply better bottom end power with it on!!
I have 2 egt probes, both identical edge brand for my insight. both are in the back of the exhaust on the driver & passenger side. When using mat's extreme race tune & atlas 40 ficm tune i have seen temp above 1500 F! I back off the throttle asap & have tuned down after seeing these temps, not towing. So that 100 degrees is important to my truck/turbo/engine!
My pyrometer is in the same place as yours. And I have only hit 1400 the one time when I was racing, er, speed engineering! I also only pull my 5th wheel at 55-60 going up long grades. I drive like an old man when towing, and it has kept me trouble free for 60k miles
on
There are so many variables to achieve different things that a "cookie cutter" answer isn't going to work.
Of course, on the flip side of this, I've seen locals around here that pulled the cat and didn't get any change in EGTs, mainly due to the fact that they also tuned it and they like to leave things on the hotter tunes and they do drive like a bat out of hell all of the time.
But this isn't a necessary mod even with a bigger turbo, bigger stixs, just depends on how you do it all.
bakos
12-01-2012 07:58 PM
