86 302 EFI issues
Old Aug 6, 2012 | 04:21 AM
86--F250's Avatar
86--F250
86 302 EFI issues
Hey guys,
Ok I have an 86 F250 302 EFI that wont start unless some carb cleaner is sprayed in the intake or, it was just ran. and once it starts, it wont idle very long without stalling. *note this engine was just switched to EFI and at the moment it does not have o2 sensors hooked in. i thought it would run without them. could this be the issue?
thanks
Old Aug 6, 2012 | 06:31 AM
Franklin2's Avatar
Franklin2
Run the codes from the computer and see what you get(besides a O2 error code).
Old Aug 6, 2012 | 05:55 PM
86--F250's Avatar
86--F250
Dad said it threw a tps code for voltage being off....
Old Aug 6, 2012 | 06:56 PM
ctubutis's Avatar
ctubutis
The TPS is pretty important, I'd correct that problem and see what happens afterwards.
It should run without O2 sensors but it won't run optimally.
Old Aug 6, 2012 | 07:22 PM
86--F250's Avatar
86--F250
you mean like replace it or what?
Old Aug 6, 2012 | 08:13 PM
ctubutis's Avatar
ctubutis
Well, I don't know, you never explained what kind of EFI system you put on it or what the exact error message was or what else you may have done or what wires are hooked to what or what you did to convert it or what you converted from, we here really know very little about your setup or your problem and so there's really not much anybody here can do to help with such little information.
If you go Googling about how to test a TPS you will probably run across methods using an ohm meter, a TPS is only a mechanical rheostat like a volume **** on a TV or radio. Some people do some tests with volt meters, too, or so I seem to recall.
Old Aug 6, 2012 | 10:22 PM
1983F1503004x4's Avatar
1983F1503004x4
If it's bad enough that the computer says that it's bad, then I'd imagine it's bad.
Of course, such may not always be the case.
Old Aug 7, 2012 | 10:01 PM
86--F250's Avatar
86--F250
https://www.ford-trucks.com/forums/1...ont-start.html
Old Aug 7, 2012 | 10:37 PM
ctubutis's Avatar
ctubutis
Are you suggesting that people will somehow remember that you posted a different thread over a month ago (almost 2 months) that contains the information that should be in your first post in this thread?
I hope not, I rarely even look at who the author is until afterwards and, even at that, it's only sometimes.
I don't display signatures or avatars, I tend to whip through things unless I find something I can help with.
Old Aug 8, 2012 | 05:48 PM
86--F250's Avatar
86--F250
sorry dude. jusy kinda figured it was easier to put that thread up than to explain everything again
Old Aug 8, 2012 | 09:44 PM
ctubutis's Avatar
ctubutis
OK, I see who you are now.
While a TPS could conceivably cause your problems, have you checked your fuel pressure & output rate at the engine?
websthes
Nov 29, 2009 07:17 AM
Icys82GT
May 9, 2007 06:47 PM
diverclimber
Nov 13, 2004 04:14 PM
Sedric
Dec 21, 2002 10:34 AM
alnbrgr
Sep 17, 2002 04:05 PM
