Would it be possible to put an EFI setup on a '72 302? Would the intake bolt up to the old heads? What sensors are used as inputs to the EFI computer? Has anyone done this?
I haven’t done this! Likely never will, but...check out JEGS they list a kit from Holley and another from Edelbrock for EFI retrofit on carbureted small block Ford engines.
William in Atlanta
I think that the only problem you'd run into is that the newer EFI blocks have the knock sensor in the block. You need the knock sensor so that the EEC-IV processor can adjust timing, etc. My 2 bits.
Greg
I have put the multiport injection from an 86 on to an 84 block that had the tpi injection on it. As far as a knock sensor, the 86 doesen't have one but if you went with one that did I am sure you could find a place to mount it on the block. It is a pretty straight forward deal, it would be alot easier if you had the doner vehical on hand as I didn't and have had to got get parts from the junk yard every week. You can see mine at the following site. If you have any questions please ask.
Robert
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
