Computer Chips & Tuners
help....speed limiter
Old Jun 27, 2003 | 10:35 AM
  #31
FTE Ken's Avatar
FTE Ken
The code will be based off ERR1. ERR1 is the latest revision in that code family (ERR0 is the 1st revision).
Old Aug 11, 2003 | 12:28 AM
  #32
nevadabandit's Avatar
nevadabandit
Unhappy help....speed limiter
I have a 94 4.0 ranger with a 5 speed and have come to hate the speed limiting feature. I live in Nevada and travel on roads where I wont see another automobile for 35 miles or more.
When I want to get out and roll the damn limiter will kick in some where just under 100 mph, I feel that this could be disconnected in the transmission some how and heres why. When I leave the truck in 4th gear and let it roll up, the tach will go to 5K and pull the little truck to about 105 mph and then its tongue is hanging out, and when I shift to 5th the rpm is just over 3500 and the damn limiter kicks in and holds the ignition out until it drops below 3500 rpm. There has to be a like to the trans that tells the computer its in 5 and then it controls the ignition to under 3500.
If it were a speed thing, the truck would not go to 5 grand in 4th because the truck is running faster there in 4 than it will run in 5th.
Any thoughts on how to dissable the information getting to the computer that the manual transmission is in 5th?
Thanks!
Old Aug 11, 2003 | 01:50 AM
  #33
FTE Ken's Avatar
FTE Ken
There are two limiters: speed limiter and rev limiter. You're not going to get around it doing what you're talking about. Only way is to try chipping it.
Old Aug 28, 2003 | 12:11 AM
  #34
Vir_Dragoon's Avatar
Vir_Dragoon
propellerhead
View User's Gallery I've also read that you can pull the fuse that protects the gauges, which includes your speedometer. If your speedometer never reads 98 mph, your governor will never kick in. However, your dash will be dead.
In some other thread, someone posted the schematics for a speed governor hack. But it warns about not being for the novice electrician. You'll need a few parts from Radio Shack to do the fix.
I had the same concerns, but finally decided to go with a chip.
I have a question for you. If it is possible could you be able to get the schematics for me? Because I have done this kind of hack on a '89 camaro z28 so I thought this could be a good project for me for my '02 Ranger even though its alot different I would like to try instead of buying a computer chip. Thanks.
Old Aug 28, 2003 | 06:49 AM
  #35
FTE Ken's Avatar
FTE Ken
If you defeat the speedometer your vehicle will not shift correctly because the computer needs the speedo reading for this.
Old Jan 2, 2004 | 04:31 PM
  #36
ranchoranger's Avatar
ranchoranger
I just got a new 03' Ranger XLT 3.0 5spd. I was coming back from the desert and decided I would see what it felt like over 100 mph..... Much to my surprise it would not do any more than 92 mph. I was ticked off at first, but later came my senses and figured I'd be better off not going over 92 mph. After reading all the options on overriding the governor/limiter it looks like I'm going to keep it running the way it was engineered.
Old Jan 8, 2004 | 04:16 PM
  #37
OdinVII's Avatar
OdinVII
good thinking
It's great that you came to the conclusion you didn't need to speed :-)
Funny story though, after I bought a Diablo chip for my '97 F150 (maybe a week and a half later) I decided to race my best friend in his '83 GMC Jimmy with a 400 SB...Needless to say, I won...but we both lost our licenses for 6 months :-)
Luckily, the sheriff only clocked me at 85...good thing he wasn't around a moment earlier
BTW, the Diablo chips are freakin' awesome!
BII Plow Truck
Apr 9, 2025 05:43 PM
Alex Latifi
Jun 4, 2024 05:26 PM
mikestyle
Feb 1, 2017 04:19 PM
Jerry Fields
Aug 22, 2016 11:44 AM
wantaford
May 11, 2010 10:43 PM
