Need for speed
Old Aug 12, 2016 | 10:04 AM
Jerry Fields's Avatar
Jerry Fields
Need for speed
Are there automatics transmission options for 77 F 250? The 3 speed c6 won't cut it for for today's highway speed limits.
Old Aug 12, 2016 | 11:48 AM
beartracks's Avatar
beartracks
Stick a Gear Vendors OD on the back of it.
Old Aug 13, 2016 | 08:09 AM
Gary Lewis's Avatar
Gary Lewis
I'm told an E4OD will work. However, you have to use one from a 460, and I know for sure that the 460's flywheel sits almost 1/2" further aft than the flywheel on an M/400. Some have said the E4OD doesn't care about that difference and works just fine bolted on these engines, but I can't say as I've not tried it.
Tim has a kit to space the flywheel back for use on a ZF5 installation, so if I were doing an E4OD swap, and I certainly might, I'd use the spacer from that kit. Then you'd know the flywheel is where it should be and that means the torque converter is where it should be. However, you will then have to use a starter from a 460 since the flywheel has been moved to the 460's position.
Also, the "E" in E4OD means "electronic", and that means the tranny has to have a controller to tell it when to shift. Baughman makes such a controller but it costs about $800. But you get a 4-speed tranny with OD and a lock-up torque converter so your MPG will go up and your engine noise will go down.
Old Aug 22, 2016 | 11:44 AM
azex2001's Avatar
azex2001
The GV is about $2K plus drive shaft mods. Will probably outlast the C-6.
teched
Sep 18, 2018 10:19 AM
scollet
Mar 12, 2011 11:48 AM
agfordman
Sep 5, 2010 09:51 PM
banjopicker66
Apr 10, 2010 10:27 PM
Bill Mole
May 10, 2008 12:35 PM
