Computer Chips & Tuners
New ECM?
Old Dec 29, 2003 | 05:44 PM
NJbronco138's Avatar
NJbronco138
New ECM?
last year when I had my E4OD rebuilt the tranny guy told me I should get a New computer because it would control the tranny a better then the one i have. I also remmeber reading somewhere that new computers have updates on them that will also run the engine a little better. A new ECM is 200$ I don't mind spending the money espcially if it will help the tranny live longer. But I want to be sure I get a computer with the Updates. The local ford parts counter said he didn't know for sure if the one he had listed was one with updates. He did say it was a updated part number. I was told they needed my vin number to look up the computer and he said he didn't. This is the part number F2T2-12A650-CC. Would that be the right one? Is it worth it for me to switch them? thanks in advance for any help
Old Dec 30, 2003 | 06:30 PM
NJbronco138
or maybe should I just get a chip to correct all of that?
Old Jan 2, 2004 | 11:49 PM
FTE Ken's Avatar
FTE Ken
What did he mean by "better"? What's the PCM code on your current computer?
Old Jan 2, 2004 | 11:53 PM
NJbronco138
I don't know what the code is, I can check if its not a lot of trouble. this was a while ago, but What I believe he told me was that it ran more line pressure, and that would be beter for the tranny, and i think he said something about it shifting differently. thanks
Old Jan 2, 2004 | 11:58 PM
FTE Ken's Avatar
FTE Ken
The PCM code is on a white sticker on the computer box. Large font letter/number combination.
Old Jan 3, 2004 | 12:00 AM
NJbronco138
I can try to get that kick panel off and take a look tomorrow. Is their any truth to an updated PCM? I'm pretty sure mine is an the orginal computer. I dont' know if they had different PCMs for different broncos. Oh the tranny is an E4OD.
Old Jan 3, 2004 | 08:10 AM
95 F150's Avatar
95 F150
You don't need a new computer, you need a Diablo chip. I've got one and it work's good. A new computer box will not help because they are year and engine/trans combo specific. The chip will "update" the computer and it will run alot better.
Old Jan 5, 2004 | 09:47 PM
FTE Ken's Avatar
FTE Ken
Yes, different ECMs do program the tranny differently, though the difference is usually not as dramatic as some might tell you (Ford programmed these things with common goals in mind).
Old Jan 6, 2004 | 12:34 AM
NJbronco138
Yeah, maybe then I will go with some sort of chip then. I looked at the kick panel and I didn't quite see how to get it off. I didn't see and screws and i didn't want to just pull on it.
Old Jan 7, 2004 | 12:30 AM
FTE Ken's Avatar
FTE Ken
Here are the two locations:
http://www.motorhaven.com/Web_store/Html/chipcodes.html
If you can't find on the easier location, let me know and I'll post removal instructions (lengthy).
Old Jan 8, 2004 | 03:50 PM
NJbronco138
I think i found it. THe sticker was beat up and dirty, but It looks like PS2G.
Old Jan 8, 2004 | 05:04 PM
FTE Ken's Avatar
FTE Ken
The sticker will aways be in one of the following formats:
L
LN
LNLN
LLLN
L = letter, N = number.
You supplied LLNL.
Pedplar
May 22, 2013 09:48 AM
bazeven2
May 4, 2011 05:15 PM
bazeven2
May 2, 2011 12:10 PM
Iggy1001
Jul 16, 2005 08:17 PM
djLariat
2004 - 2008 F150
Mar 12, 2004 07:43 AM
