Melling LPOP Install
Old Aug 10, 2012 | 10:05 AM
  #31
John7894's Avatar
John7894
No need for an impact. Just use the "breaker bar on the frame rail" trick and bump the starter. Pops right off and then just use a ratchet to get it out the rest of the way.
Curious what your low oil pressure problem is though Tim. Keep us posted.
Old Aug 10, 2012 | 10:11 AM
  #32
Snowseeker's Avatar
Snowseeker
Guess you never took any teeth off a flywheel in your life? Its not funny.
Old Aug 10, 2012 | 05:13 PM
  #33
John7894's Avatar
John7894
Nope, never have. The bolt is not as tight as some think it is.
Old Aug 10, 2012 | 05:36 PM
  #34
timmyboy76's Avatar
timmyboy76
I heard about the breaker bar under the frame trick, but wasnt about to try. Hopefully, this will be the last lpop i mess with for awhile. Back to the pressure, not sure guys, it sits a perfect 5psi when oil is warm. I'm bet'n its on placement of sensor. I did the wood-n-things / Springerpop bypass method, and "T-d" the line there at filter, for the sensor. Beginning to think, that may be the problem. Other than that, without the gauge, one wouldn't know. Glad i got them gauges. When i get back from river, gonna undo the "feed" line to filter, and install gauge there, see whats REALLY goin on....
Old Aug 11, 2012 | 10:26 AM
  #35
Snowseeker's Avatar
Snowseeker
Not sure on the torque of the 7.3 crank bolt but all it takes is one bad time and you'll be pulling a trans.
Maybe I'm the strange one but I try to do things the right way to avoid extra fun.
Old Aug 12, 2012 | 11:26 PM
  #36
Kdr358's Avatar
Kdr358
I have discovered my Lpop to be leaking very badly today so this week I will be ordering the Melling pump from Clay. I have a standard h/b removal kit/tool, I assume that works?
Old Aug 13, 2012 | 07:26 AM
  #37
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Yeah, that works, I also rented a tool from O'Smelly's to press it back on so I didn't have to do the longer bolt method.
duck fan
112
Aug 21, 2023 09:52 AM
bulla
1983 - 2012 Ranger & B-Series
Apr 8, 2019 01:59 AM
1loco
Oct 3, 2013 07:54 PM
ford2go
Garage & Workshop
Dec 28, 2012 08:08 PM
PaysonPSD
29
Oct 2, 2011 03:04 PM
