Dual batteries
Old Aug 1, 2012 | 09:27 PM
Miera85's Avatar
Miera85
Dual batteries
Im wanting to put dual batteries in my 73 f250 HB with a 390 does anyone know if I need to do anything special under the hood to make it work or is it pretty basic?
Old Aug 1, 2012 | 09:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Do you want the second battery so you can power a camper (like the factory setup) or do you want the second battery for increased cranking capacity?
Old Aug 1, 2012 | 09:47 PM
Miera85's Avatar
Miera85
mainly cranking. with the occaisional camper. Also i run a lot of fog lights and spotlights (not sure if they run directly threw the battery or not?) and the seem to get dim when i slow down. but either way i would like to put dual batteries if possible.
Old Aug 1, 2012 | 09:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The reason I asked was because the two systems would be wired differently.
In the factory setup when the truck is not running, the auxilliary battery is isolated from the trucks electrical system.
There is a solenoid mounted near the aux battery, when the ignition is off, the solenoid is open and the battery is isolated from the electrical system, that way if you have a camper or something else hooked up to that battery you can power it untill the battery runs down without having to worry about killing the main battery and not being able to start the truck.
When you start the truck, the auxilliary solenoid closes and now the dead aux. battery will be charged by the alternator.
If you want the battery for increased cranking capacity all you need to do is add the second battery and battery tray, then wire the two batteries in parallel (+/+,-/- like hooking up jumper cables). If you use two identical batteries this effectively doubles your cranking capacity.
If you want it for increased cranking capacity AND be able to power something without worrying about killing the main battery, you'll need to add the auxilliary solenoid and wire it so its closed in BOTH start and run positions but open in the off position.
Here is the illustration from the parts catalog.
Click on the .pdf link to view.
File Type: pdf
Old Aug 1, 2012 | 10:03 PM
Miera85's Avatar
Miera85
alright thanks for the info. I dont have to hook the camper up as i dont typically do that. i just figured if i was going to add another battery i could start.
Old Aug 1, 2012 | 10:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
See my post above, I added the illustration of the system from the Ford parts catalog.
Old Aug 1, 2012 | 10:11 PM
hasteranger's Avatar
hasteranger
btw extra batteries won't do anything for driving lights and ETC... if you are drawing near what your alternator can put out, it doesn't have the extra wattage/amperage to feed one battery. In that situation adding a second battery just adds to the strain on your alternator. If you are drawing more power than you are making, you need a bigger alternator.
Old Aug 2, 2012 | 12:36 AM
Behemoth's Avatar
Behemoth
While I am in no way a sponsor of theirs, you might want to Google "Hellroaring Technologies". They have a product that serves as a battery isolator that you can switch over from the secondary battery just serving as a power source for your trailer, to a cranking battery with the flip of a switch. They also claim that their isolator has a much more efficient power transfer rate than the typical diode isolators, with little to no bleedoff. I don't know if any of those claims are perfectly true, but I put one in Buford to see how it would work out. If you use a product like this, you'll need to upgrade the cables going to the secondary battery to be at least as beefy as the primary, so that it can be used as a cranking battery as well.
Anyway, thought I'd offer up another possible solution to the scenario. I haven't tested mine out yet, but it wired up easily enough (well, I was wiring the whole truck at the time, so it was just part of the job). Hope that helps a little.
Old Aug 2, 2012 | 01:32 AM
HIO Silver's Avatar
HIO Silver
It'd be awesome if ya could find some rust-free and newly refinished factory battery trays :
A few webpages for your information:
NBC_Steve's installation: https://www.ford-trucks.com/forums/1...-with-pix.html
Dual Battery Installation
Dual batteries - FSB Forums
Old Aug 2, 2012 | 03:29 AM
gpence's Avatar
gpence
[quote=HIO Silver;12125422]It'd be awesome if ya could find some rust-free and newly refinished factory battery trays :
I think I have a couple 2 or 3 laying around on the self if ya can't find any in your area
Warhound
Apr 28, 2018 03:46 PM
Tackelbarry
17
Aug 16, 2016 08:21 PM
Dace
22
Jun 9, 2016 12:50 AM
Drew2010
Offroad & 4x4
Dec 26, 2007 07:22 PM
dustinova
Electrical Systems/Wiring
Oct 13, 2006 12:22 PM
