Dual Battery Ideas
Old Oct 5, 2006 | 05:43 PM
dustinova's Avatar
dustinova
Dual Battery Ideas
So the truck that I just inherited from my Dad is a 1978 F-250 4x4 Camper Special. It has a dual battery setup, and I can't think of anything that I would need dual batteries for. So what are some things that you all have run on your trucks that dual batteries would be usefull for?
Old Oct 5, 2006 | 06:06 PM
Franklin2's Avatar
Franklin2
One battery can be the normal automotive type battery for starting. The other battery can be a deep cycle.
The deep cycle battery and it's loads are seperated from the normal starting battery by either a battery isolator, or in some older setups, by continuous duty relays. Look around under the hood and see if you have any extra relays that look like starter solenoids. The isolator or relays let the alternator charge both batteries, but keeps the loads from draining the starting battery. This is handy for a camper when you are out in the boonies, and want 12 volt power, but do not want to drain the starting battery that starts the engine.
Old Oct 6, 2006 | 09:32 AM
ness0012's Avatar
ness0012
I've heard that many desil trucks have two batteries but I'm gonna get two 750CCA batteries when my 1000CCA goes because it'll have a larger reserve for running my air comp and winch.
Old Oct 6, 2006 | 02:22 PM
Franklin2's Avatar
Franklin2
Diesel trucks have two batteries because they are harder to start in the winter. They need fast cranking speeds to build compression. The batteries are hooked together so they are essentially one large battery.
Old Oct 6, 2006 | 03:06 PM
dustinova's Avatar
dustinova
So any ideas on how I can utilize my dual battery setup? I don't plan on getting a camper any time soon, so what else could I do?
Old Oct 8, 2006 | 07:19 PM
chrono4's Avatar
chrono4
most people use them for winches, lots of lights, sound systems ect. In my bronco when the subs hit, it will draw so much it looks like I'm flashing my brights, so thats why I run 2.
Old Oct 11, 2006 | 09:16 PM
gbrett's Avatar
gbrett
I have 2 in my Bronco mostly for winching I have mine isolated using a continous duty solinoid on a switch so I can only draw off my aux batt with my winch when I may need my main batt to start the truck later
Old Oct 11, 2006 | 09:24 PM
chrono4's Avatar
chrono4
I did mine the other day, but dont have the isolator yet. Just ran them parallel, helps alot with amps draw. Lights dont dim nearly as bad now, and the volts stay up. Get paid tomorow, buying the isolator and a rear locker, so It'll be good then.
Old Oct 12, 2006 | 08:26 PM
ness0012's Avatar
ness0012
ooh cool, new locker hu. what kind are you putting in?
Old Oct 13, 2006 | 12:22 PM
chrono4's Avatar
chrono4
well, gonna weld up the front end, and just looking for a ratchet locker for the rear. guess Ill see how long i can make that 44 last.
