i finally got the timing chain off and switched to the 0 setting on the crank gear. i gotta pick up a new timing cover gasket and then ill put it all together and fire try to fire it. ill let guys know how it goes thanks everybody for all the help the 3 key was has me really confused
Great! Let us know what's up just as soon as you get it back together.
all i can tell u is i took the timing cover off and all i did was move the crank gear from the square to the zero. it wouldnt run before and as soon as i switched it it fired rate up and runs good now
