little can?
Old Aug 8, 2012 | 05:40 PM
Trashyvixxen's Avatar
Trashyvixxen
Wink little can?
What is the little can looking thing on the right fender area of my truck, I saw someone talking about one the other day and I can't find the post on it.
What I am actually looking for is a TINY vac. hose that is the size of electrical wiring that goes to the lever on top of the heater motor and hits a Y to the can thing. lol I know I can't remember the names to anything today. If someone can decipher what I am saying and can help I would appreciate it.
It is making me feel like the woman that goes to the parts store and is asked the make and model and says RED. LOL
just fyi 80 inline 6 1/2 ton f150 with a 4 speed( actually 3 w/od)
Old Aug 8, 2012 | 06:09 PM
ctubutis's Avatar
ctubutis
I can think of 3 cans on the RH (pass) side...
1) A silver, pinkie-finger-sized one with one wire coming out, it's a radio noise suppression condensor.
2) A square can (frequently has the above-mentioned small can on it) is the voltage regulator.
3) Some trucks will have a Hi-C fruit juice can on the pass wheel cover, this is a vacuum reservoir.
Old Aug 8, 2012 | 06:13 PM
Trashyvixxen
That would be number 3 , looks like a traditional can that you would pull out of the pantry for lunch lol. Thanks.
Old Aug 8, 2012 | 06:36 PM
ctubutis's Avatar
ctubutis
OK. It's VRESER (or VRESR, I forget) on your vacuum hose routing table under the hood on the radiator support.
Old Aug 8, 2012 | 07:26 PM
Gary Lewis's Avatar
Gary Lewis
Engine vacuum goes to it through a check valve and a tee. The check valve keeps the vacuum from being lost when the throttle is nailed. The tee takes vacuum through a tiny plastic tube into the cab to run the HVAC system via a grommet in the heater box.
Old Aug 8, 2012 | 07:29 PM
LARIAT 85's Avatar
LARIAT 85
Some trucks have two vacuum reservoirs on the passenger inner fender.
My 1985 F150 Lariat has a black plastic round ball that is used for a vacuum storage canister for the climate controls. This "death star" has a vacuum hose that connects to a round vacuum tee that then connects to the three-port plastic vacuum tree on the firewall.
The other is larger and is shaped like a coffee can. It is made of metal and has a single vacuum hose with a check valve inline that routes directly to the metal vacuum tree that is screwed into the back of the intake manifold. I think this one is used for the cruise control.
Old Aug 8, 2012 | 07:56 PM
ctubutis's Avatar
ctubutis
I knew of the Death Star ball for the HVAC system, the fruit-juice can I assume was for the engine-control solenoids.
Old Aug 8, 2012 | 08:26 PM
Galendor's Avatar
Galendor
My '86 has only the "death star" vacuum ball - no fruit juice can anywhere. And my truck does have functioning cruise control.
To the original poster (Trashyvixxen), the thin-diameter vacuum line/hose you are looking for is probably made out of a hard plastic-like material. If so, this kind of vacuum line is sold at some general auto stores (like Autozone, etc.) in relatively short lengths. Show an employee at the store (preferably an older guy or gal) what you need and they can probably direct you to it, as well as other vacuum fittings such as the little "Y" piece you mentioned.
The vacuum line can also be replaced with rubber (EPDM) vacuum line from the auto store, probably 3/16" inner diameter which they should have on big spools.
How or why do you know you need to replace this vacuum line? Is is cracked or accidentally cut?
Old Aug 9, 2012 | 09:18 AM
Trashyvixxen
Wink
It is in two pieces ..lol I am slowly going over her, I just got her a couple of weeks ago and spent most the time re-doing the brakes so now I am doing other stuff but she runs pretty well so far, a little rich but I don't want to touch the carburetor just yet LOL I need to driver her while in the process of fixing stuff.
Old Aug 9, 2012 | 10:22 AM
LARIAT 85's Avatar
LARIAT 85
Interesting. If it isn't used for the cruise control, I wonder what the metal fruit juice/coffee can vacuum reservoir is there for?
Old Aug 9, 2012 | 10:31 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Those hard plastic vacuum tubes are notorious for cracking/breaking. You use a short piece of rubber hose to "splice" it back together. Just make sure it's a snug fit on the plastic line.
FWIW, trucks without factory A/C or cruise, don't have either of these vac res.
I always thought the ball was for A/C, and the can was for cruise. I pulled one of each from an 85 Bronco that had both A/C and cruise.
Old Aug 9, 2012 | 08:31 PM
Galendor's Avatar
Galendor
I have no idea, I have wondered that myself.
Old Aug 9, 2012 | 08:34 PM
Galendor's Avatar
Galendor
They are thicker-walled than I would have thought. I cut one in half at the junk yard and was impressed with the wall thickness and general toughness of the plastic line. The one I cut was one coming from the vacuum solenoids on a 1985 I-6. But maybe some of the others are thinner/weaker.
Old Aug 9, 2012 | 09:41 PM
ctubutis's Avatar
ctubutis
Look on your Vacuum Hose Routing Table under the hood. The reservoir is either VRESR or VRESER, there are various other vacuum amplifiers, solenoids, valves & check valves all connected together that sometimes have vacuum, other times not.
02chuck
Oct 9, 2016 11:14 PM
barnbridge
Oct 3, 2015 11:01 AM
Eallend7
29
Nov 17, 2012 10:18 PM
veniz23
1978 - 1996 Big Bronco
Sep 10, 2004 09:04 PM
jeff Heidel
Jan 12, 2004 09:39 AM
