Got it done
Old Jul 29, 2012 | 10:53 PM
Bonanza35's Avatar
Bonanza35
Got it done
Well it took long enough but I got the IP, injectors, glow plugs and return line done. Bad part is that I had to do the IP twice. First time, because its a van 86, I removed the gear cover for the pump. Got it in and it started but smoked real bad. I marked everything but still managed to get it installed a tooth off. Brought it to TDC removed cover and pump and started over. Lesson learned, easy way isn't always the best way. Now I have to find somebody who can fine turn it. Drove it little over a mile without the engine cover on, seems to have lots of power, just a little bit to clanky for me. I guess that means to far advanced. A couple of little hills by me to, it dose have more power then before.
Chet
Old Jul 29, 2012 | 10:58 PM
Bonanza35's Avatar
Bonanza35
I want to say thanks to all who replied to my posts for there help, and Typefour for his injectors and return line kit. I didn't know anything about these IDI diesels. Plus I'm a cancer surviber just out of treatment so energy is still quite low. Thanks and God bless,
Chet
Old Jul 29, 2012 | 11:25 PM
hairyboxnoogle's Avatar
hairyboxnoogle
The loud rattle may just be from the stronger pump and injectors, i would assume the higher pressures would make it louder. If you can see the scribed alignment marks on the pump, lining those up is generally within 1-2*
Old Jul 30, 2012 | 12:09 AM
Ford F834's Avatar
Ford F834
If you want to take a stab at timing it, Dave Sonaugle has a pretty good write up on how to time an IDI by ear. Basically "Powerstroke rattle" when cold with cold timing advance on (you can hot-wire it once the engine is warm to simulate it being cold), then rattle gone when warmed up (or hot-wire removed). Read his description in this post:
https://www.ford-trucks.com/forums/8...breakdown.html
I don't want to start another heated debate over timing meter vs. timing by ear, I just thought I'd offer it as a "free" way to check out your timing and maybe you will be happy with it. Dave S swears by this method, because timing meters are dependent on the timing marks being correct, and he claims his is off by 3 degrees and knows of other owners who have experienced incorrect timing marks also. Read about it in this thread, note post #15...
https://www.ford-trucks.com/forums/9...-question.html
Anyway, if you mark your pump position, you can always put it back, and Dave's method does not cost you anything to try... just sayin'...
Old Jul 30, 2012 | 12:17 AM
ihateminimumwage's Avatar
ihateminimumwage
Better to have it just slightly retarded, I cooked a set of GPs in under a year having the IP advanced a little too far.
Old Jul 30, 2012 | 10:40 AM
Bonanza35's Avatar
Bonanza35
Good read Ford D83. I just mit give it a try. I don't think anybody here has the right stuff for the job anyway.
Chet
ford7.3l
May 15, 2014 08:33 AM
Hyperzombia
Nov 4, 2013 11:01 PM
eatont9999
25
Jun 26, 2011 12:42 PM
Royson12
19
Dec 3, 2007 11:38 AM
bl311
Nov 8, 2006 11:15 PM
