Problem with power steering
Old May 11, 2003 | 06:41 PM
teederj2002's Avatar
teederj2002
On my 89 F-150 300 I-6 when it idels and i turn the steering wheel the rpms drop and if i hold it long enough it dies. Whats the problem
Old May 11, 2003 | 08:46 PM
fordtruckenthusiast's Avatar
fordtruckenthusiast
Check the fluid level.
Does the PS actually work? (is it hard to turn?)
Old May 11, 2003 | 09:40 PM
teederj2002
I just added some last month because when i bought it it was empty and it turns fine now and it turned easy with out it it just made a lot of noise
Old May 11, 2003 | 09:55 PM
fordtruckenthusiast
Is there anyway you can have a friend mess with the steering while you are watching the pump?
As far as I know the pump is completely mechanical. That means that for the steering to be causing the bog down it would meant that either there is a problem with the belt or the pump is begining to freeze up. OR... There is a clog in the lines (possible?) that will not allow the pump to turn correctly, thereby slowing down the engine? All hypothetical...
Check the belt, is it worn?
I've "blown" up several PS pumps on my '83. Everything from offroading to plain forgetting to check the fluid (I.e. bad maintnence)
Anyhows, if you can see what's happening with the pump it'll help to narrow down the problem. Make sure the pump is turning correctly when your friend is checking the steering. Try checking out the lines that are hooked up to the pump
Old May 11, 2003 | 10:57 PM
kcw12's Avatar
kcw12
My truck is doing that too... I also have a leak in the high pressure line
Old May 11, 2003 | 11:17 PM
Ford_Six's Avatar
Ford_Six
If the truck is EFI, it should have a pressure switch on the high pressure side of the pump, or in the line, to tell the computer to up the idle. If this switch is bad, the idle will not be increased, and the engine idle can be dragged down far enough to cause a stall.
Old May 12, 2003 | 09:28 AM
snapper1's Avatar
snapper1
If you do find out your p/s pump is shot then upgrade to a AGR unit
I did and you will never have to listen to Fords stock noise maker pump again.
P.S. Why are ford p/s so noisy? Even the newer rigs.
Snapper1
Old May 12, 2003 | 11:42 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Hey Snapper1, Where can I find an AGR unit? I would love to get rid of the Ford factory noise maker. Mines startin to leak now too.
Old May 12, 2003 | 01:57 PM
snapper1's Avatar
snapper1
Go to agrsteering.com Most 4x4 part stores also carry the line and the pump can go for as little as $120.00
If you got the cash and want to restore your steering to it's full potential then I would get the pump and the box.
Snapper1
adatsmaddog
Oct 17, 2013 12:11 PM
fordservicetrk
Jan 14, 2011 12:42 AM
bansheeduner
Jan 9, 2008 10:42 AM
lunchbox0330
Sep 13, 2007 12:12 AM
Bronco-Red
1978 - 1996 Big Bronco
Jun 7, 2004 01:05 PM
