1983 F250 Steering Problems
Old Sep 10, 2007 | 10:28 AM
lunchbox0330's Avatar
lunchbox0330
Hello I have a 1983 Ford F250 with ten inches of lift and 44's on it and I have been having problems with the steering. I had broke a steering box, so I had replaced that and put a new power steering pump in and it still doesnt steer right. Any Suggestions. Thank you
Last edited by lunchbox0330; Sep 10, 2007 at 10:29 AM. Reason: spelled something wrong
Old Sep 10, 2007 | 12:35 PM
redneckte's Avatar
redneckte
your suspension lift is throwing your steering geometry off
Old Sep 10, 2007 | 12:38 PM
greythorn3's Avatar
greythorn3
Duh, lets see there beavis... u should be happyyou have steering with 44's and 10" of lift.
Old Sep 12, 2007 | 05:49 AM
Chiefrider007's Avatar
Chiefrider007
Have you checked wheel bearings, ball joints, tie rods and ends?
Old Sep 12, 2007 | 11:56 AM
f100jim's Avatar
f100jim
Any Suggestions? Yeah. Put the original size tires back on it and remove the 10" lift kit. If you want a "monster truck" you have to build it from scratch with a custom frame and suspension. With those tires and a 10" lift kit, about the only thing it will be good for is breaking parts.
Old Sep 12, 2007 | 02:28 PM
big hoss 29's Avatar
big hoss 29
Do you still have the TTB front axle under it or did you swap in a solid axle? With a 10" lift and 44's, that's a lot of weight to try to steer around and your stock setup is not up to it. Heck, these truck wander around the road with stock tires! You probably need to look at going to a full hydraulic steering setup.
Old Sep 12, 2007 | 11:01 PM
lunchbox0330
Any idea where I would look to purchase a hydraulic steering setup?
Old Sep 12, 2007 | 11:02 PM
lunchbox0330
If I was looking for a sarcastic remark I would have asked for one thanks anyways.
Old Sep 12, 2007 | 11:27 PM
big hoss 29
I'm not 100% sure where to get a hydro steering setup, but the guys in the offroad forum might be able to help you out. I think A few guys run them and they like the fact that they don't wander all over the road.
Old Sep 13, 2007 | 12:12 AM
lunchbox0330
Thank You. Looking for any suggestions about where to find a hydro steering setup.
DavidJO
Nov 30, 2016 06:07 PM
dmp1983
Nov 4, 2012 11:28 AM
1fast93stang
Mar 20, 2010 02:39 PM
Country705
Jun 15, 2008 03:27 AM
MER
Jan 31, 2008 06:55 PM
