A/c not blowing sometimes
Old Jul 28, 2012 | 09:14 AM
2002exPSD's Avatar
2002exPSD
The front a/c on my ex on the highest blower motor speed blows out the vents like its on low, but I can hear the motor blowing at full speed. It's not blowing out of defrost or floor unless I switch it. On lower settings I can barely feel any air at all. Only does this rarely. Could it be my vacuum pump?
Old Jul 28, 2012 | 12:58 PM
Monsta's Avatar
Monsta
Sit. Stay.
So all the mode settings work properly, right? It's just the speed or volume of air coming from the vents is not sufficient? You say it rarely does this. Any pattern?
If you are sure that when it does this the air isn't coming out of a vent it is not suppose to, then I might suspect the fan. But I haven't ever heard of a fan going bad.
This wouldn't have anything to do with a "vacuum pump".
Old Jul 28, 2012 | 01:35 PM
2002exPSD's Avatar
2002exPSD
Does it when I first start the truck on the hottest of days. If I shut the truck off and restart then all is well.
Old Jul 28, 2012 | 10:53 PM
LunaticSVT's Avatar
LunaticSVT
Simple check is to look and make sure that something hasn't gotten sucked up into the recirculating air inlet duct in the passenger's foot well. Just get on that side's floor and reach up in there to see. Amazing what a thin piece of plastic baggie will do.
Old Jul 29, 2012 | 06:29 AM
2002exPSD's Avatar
2002exPSD
Hmmmm that is possible. Been running the a/c on recirc since I bought it 5 years ago. And I'm not the cleanest of people when it comes to trash in my truck.
Meatus
May 10, 2019 01:13 PM
GuitarJesus
20
Jul 24, 2018 07:11 PM
arkredneck
Dec 26, 2013 12:01 PM
bigbeige
Apr 25, 2007 08:52 PM
Mountaineer40
Dec 12, 2003 12:13 PM
