Tricky Fan?
Old Dec 11, 2003 | 01:48 PM
Mountaineer40's Avatar
Mountaineer40
Tricky Fan?
Tricky Fan????
If I have the blower on ( air coming out of the dash vents) and I add accelerate on the gas to whatever speed I am already going, the air stops blowing. When I stop accelerating the air starts blowing out again. It's been like this for a couple of years. Everything works fine other than that. Any suggestions???
M40
Old Dec 11, 2003 | 02:19 PM
lloyd33's Avatar
lloyd33
Does the blower motor actually stop spinning or does the air just stop coming out of the vents? If the motor is actually stopping then you have an electrical short. If the air is just getting blocked off then you have a vacuum leak somewhere. Does the problem still occur when you have the control set to say 'defrost' or 'floor' instead of vent?
Lloyd
Old Dec 12, 2003 | 12:13 PM
Mountaineer40
Does not matter of cool air or hot air is blowing......same thing occurs.
M40
