Won't start
Old Jul 27, 2012 | 05:12 PM
skypappa's Avatar
skypappa
Won't start
I just completed fixing the steering shaft on my 73 f250 and had to disconnect the tranny linkage. After assembling everything back I'm getting panel lights but no starter. It behaves as if it is in gear but I double checked that the tranny linkage is in Park. Why is it not getting juice to the starter? The ground is fine. This truck is an automatic.
Old Jul 27, 2012 | 06:11 PM
400 .040over's Avatar
400 .040over
there is a saftey switch on teh steering column,is that unhooked ?
Old Jul 27, 2012 | 06:15 PM
skypappa's Avatar
skypappa
No, the neutral safety switch is connected.
Old Jul 27, 2012 | 06:45 PM
fmc400's Avatar
fmc400
MSEE
Check if you have voltage coming from the wire that connects to the 'S' terminal of the starter solenoid with the key in START.
Side note: the NSS has to be aligned in addition to being connected. Run the above test first regardless.
Old Jul 27, 2012 | 09:38 PM
skypappa's Avatar
skypappa
I narrowed it down. It was indeed the neutral safety switch. I don't understand how it works though. If I hold the bar in a certain position it will start in any gear. I don't understand how to reset it or if it just needs to be replaced.
Old Jul 27, 2012 | 09:52 PM
fmc400's Avatar
fmc400
MSEE
There is an actuator pin fixed to the steering column. This pin works the switch inside the NSS. There are two screws on each side of the NSS. If you loosen the NSS, it has slack and can rotate side to side.
To set the switch, set the parking brake. Loosen the screws so that you can rotate the switch side to side and turn it all the way counter-clockwise. Turn the key to RUN and put the shifter in REVERSE. Have a friend watch your reverse lights. Slowly rotate the switch clockwise until your friend sees the lights go ON and mark that point. Keep rotating until your friend sees the lights go OFF and mark that point. Now rotate the switch slightly so that it's in the middle of the two points. Make sure the reverse lights are still ON, then bolt the switch back down. If it's set for REVERSE, it will be set for PARK too. Shut the key OFF and put the shifter back into park; the motor should start.
Old Jul 27, 2012 | 10:24 PM
skypappa's Avatar
skypappa
I don't have a pin coming off the steering column. Just the switch bolted on top with space under it to the shift tube. The switch has a bar that slides side to side. When I slide it over the truck will start but it is spring-loaded and sends the bar back to where the motor won't start.
fancyvern
1997 - 2003 F150
May 27, 2018 01:25 PM
Windstorm
Sep 17, 2014 10:22 AM
fordguy300
Nov 6, 2008 05:53 PM
Boyd
15
Feb 3, 2005 08:06 AM
bronco
1978 - 1996 Big Bronco
Sep 20, 2000 09:01 PM
