1978 - 1996 Big Bronco
whats wrong
Old Sep 19, 2000 | 08:02 PM
bronco's Avatar
bronco
whats wrong
my 351w still wont kick ive replaced the battery, cables, starter, starter soloniod, ignition mod; whats wrong does anyone have a suggestion (the engine isnt locked up)
Old Sep 19, 2000 | 11:15 PM
nitro94's Avatar
nitro94
whats wrong
You need to take a test light and see if you have power to the small wire ( 90 degree molded terminal) at the starter solenoid when the key is in start position. If not the problem is most likely a bad netural start switch located on the transmission shift lever shaft. Usually 4 wires, 2 for backup lights, 2 for netural start. Red/blue I think.
Old Sep 20, 2000 | 09:01 PM
thelonerangerxlt's Avatar
thelonerangerxlt
whats wrong
gary's1950F1
Feb 27, 2016 12:39 PM
Mab1957
Oct 21, 2015 01:25 PM
william16339
Nov 2, 2014 11:10 AM
berlincam86
33
Feb 27, 2011 07:16 PM
wolffee
Oct 27, 2008 05:34 PM
