03' 6L questions
Old Jul 22, 2012 | 11:46 PM
75diesel's Avatar
75diesel
03' 6L questions
Ok here's my situation. I have an 03 F250 with a 6.0 and was driving today with my snap-on modis hooked up and was watching my EOT and ECT. It was about 102 deg outside and running 70mph I was getting 183 ECT and 217EOT. Ok the engine oil cooler is plugged I'm thinking. I do have the EGR unplugged, and have plans in the next week or so to flush the cooling system as at 94k I have no knowlege of it ever being done. During this flush, is it possible to restore flow to the eoc or must it be replaced? I'm planning on replacing the thermostat while it's out, so any other suggestions while I'm there? Yes, going to use distilled water and refill w/ either ford gold or cat elc. I'm considering the cat elc due to having a supply of it at work and would be free for me. Also will be adding a coolant filter also.
Thanks in advance,
Travis
Old Jul 22, 2012 | 11:58 PM
BLADE35's Avatar
BLADE35
First step is to check ECT & EOT after a 12 hour cold soak they should be the same this verifys the sensors
you need a new thermostat
and if temp sensors are good then time for an Oil Cooler
Being the 03 round egr cooler you should be able to reuse it if its still ok I assume it is since there is NO Mention of smoke
Old Jul 23, 2012 | 12:00 AM
75diesel's Avatar
75diesel
Yep, scan tool still in the pickup, will check in the morn and update.
Old Jul 23, 2012 | 12:06 AM
BLADE35's Avatar
BLADE35
Iv had better luck with ELC than Gold
If you do an oil cooler replace this stuff
SS Screen under oil cooler
Turbo hardware kit
Blue spring For the FPR
Intake Gaskets can be reused but Im anel that way plus it comes with the Updated Blue Hose. if you have the original orange hose they can leak so best to change it
Coolant filter
Old Jul 23, 2012 | 12:09 AM
75diesel's Avatar
75diesel
Can't say if it has the blue spring or not, but can say it has 64 lbs @ idle. So I'm going to return the kit I already got from the dealer. Any chances of getting the EOC flushed out manually?
Old Jul 23, 2012 | 12:56 AM
Yahiko's Avatar
Yahiko
Plug the EGR valve back in when you test the deltas.
If you have an updated strategy in the ECM/FICM
you could be not running with a fan and that could
mess with the delta testing. But by the ## it's
time to replace it. You can back flush the cooler and hope
Remove the lower radiator hose and the little cover back
by the EGR cooler inlet hose and use a small bit of host
to make the end fit in so it won't leak and pulse the water
to break up the junk. It may work for a short time but it will
come back.
BLADE35 knows more on this and can tell you what I may of missed
Sean
Old Jul 23, 2012 | 01:11 AM
75diesel's Avatar
75diesel
So basically I just as well figure on replacing the cooler? No point wasting time on it if it's only a band-aid, as fixing the problem now usually will be cheaper than not. Thats what I wanted to know. I'm unsure of the pcm flash, and once I get the toilet paper plates out of the window I'll take it in to the local dealer and check/flash the pcm.
Yes I just bought the pickup about 2 weeks ago, but for what i'm into it I can afford to put some more into it and be happy. i'm sure another $600 will be cheaper than not doing it right.
Old Jul 23, 2012 | 01:20 AM
75diesel's Avatar
75diesel
Ok, after seeing the construction of a cut-away EOC on BPD's site, I'm not even going to bother with flushing it and just replace it. Thanks all!
In case anyone else want's to see:Bullet-Proof Your 6.0L Engine Oil Cooler!
Old Jul 23, 2012 | 01:51 AM
Yahiko's Avatar
Yahiko
Flush is before you replace the bad one.
The idea being to let the bad one catch the
crap. Then add the filter to it.
Sean
2000 Ex-cursion
Nov 23, 2017 07:19 PM
grainmaker181
Jul 30, 2014 10:39 PM
LSAtexan4x4
Apr 9, 2012 06:56 PM
Ben Albert
Jan 7, 2012 06:38 AM
polosabre
Nov 14, 2010 10:43 PM
