Throttle return spring question
Old Jul 23, 2012 | 11:10 PM
Opossum's Avatar
Opossum
Originally Posted by mikeo0o0o0
It has to do with the load placed on the throttle shaft.
The way the factory has it set up the throttle linkage pulls back to open the throttle. This will place X load on the backside of the throttle shaft bore in the carb. This load will cause the bore to wear.
To close the throttle there is a spring to pull the throttle shut. This spring hooks to the bottom part of the throttle arm, below the throttle shaft centerline. This means that to close the throttle the spring tension also pulls back towards the firewall, effectively doubling the load on the backside of the throttle shaft bore. All the load is placed on the backside of the throttle shaft bore. This is diecast aluminum or zinc and is relatively soft compared to the steel throttle shaft. This will make the bore wear egg shaped, causing air leakage, idle mixture problems, etc.
However, if you mount the return spring in front of the carb and attach it to the top of the throttle arm so it pulls forward to close the throttle, this effectively splits the load between the pull back of the gas pedal and the pulling forward of the return spring. This kinda evens things out reducing the wear on the throttle bore.
Originally Posted by savagehenry
So I would insert the spring into the large hole in the center of the pic. Looks like the black bracket to the left is a return spring bracket, yes?
Yup, looks right, except hooking the springS to the throttle linkage pin/ball in the narrow area in between the linkage and the arm would probably be a little better.
Old Mar 27, 2021 | 10:45 PM
Troca250's Avatar
Troca250
Where can one purchase a throttle return spring like the one you have. I also have a 390, ford parts catalog part number is D3TZ 9737-D. People say this p# is obsolete, would you know who sells this part number.
Old Apr 4, 2021 | 11:27 PM
Troca250's Avatar
Troca250
There are some minor variations and this is on an FE (390) but yours should look something like this.
What year/engine?
Were can one get the same type of throttle return spring you have on your FE 390 mikeo0o0o0. Is that the a period correct throttle return spring? I have a 390 on a 1973 ford f250 and its got the same bracket- I just need the same spring you have. Ford calls for part number D3TZ 9737-D.
Old Mar 4, 2023 | 11:39 AM
Jadesupercab's Avatar
Jadesupercab
Originally Posted by jgavac
Here's a 460 bracket. Cruise control sits on top of it
Attachment 201734
Attachment 201735
-Jameson
I have a 460 with 63,000 original miles. I have the same rear accelerator retracting spring bracket but also found one wile doing valve covers in front of the carburetor on the throttle side. It has a orange bottom and blue top. Orange is for chevy lol. Catalog reference points to a accelerator retracting spring bracket d5ta-9741-na
bolt hole goes toward the front of the engine and blue is on top. Bracket bend faces the throttle
Old Mar 4, 2023 | 12:35 PM
tbear853's Avatar
tbear853
I use two springs ...
... just in case.
Old Mar 4, 2023 | 12:38 PM
Jadesupercab
... just in case.
do you know if both brackets are factory and if so was two springs the stock set up? Just trying to understand what this is about. Looks like a aftermarket or dealer installed for something really looks like a spring bracket.
Old Mar 4, 2023 | 05:29 PM
tbear853's Avatar
tbear853
As far as I know, YES .... the two colored springs and the brackets on my intake were on the original cast iron intake and 2-barrel carb when I bought the truck in 1986, it had 35,xxx miles, was flipped from an estate through a police officer's car lot. Not a460, it's a 1977 with 351M. I've never painted the springs and I liked the way they pull. The shorter red one is actually a little bit stiffer than the long blue one. Aftermarket ones are typically silver. The end of the red spring at the intake is attached by a bracket looks like the blue one above in a post. I added a tab where the blue one hooks to the carburetor, but on the other end mine has an offset Z shape fits in a hole.
I added cruise control and a extension for kick down when putting the intake and a Holley on long ago.
Old Mar 4, 2023 | 05:47 PM
Jadesupercab
Do you recall if the bottom of the forward bracket was orange or blue underneath? It's just odd to have something not blue when everything else is. Not a big deal but definitely gets me thinking it was added. For someone needing a second spring do you have a aftermarket suggestion something you found similar to its strength?
Old Mar 4, 2023 | 06:18 PM
tbear853's Avatar
tbear853
Don't recall color underneath. In looking closer at those springs on mine, I almost see red on the blue and blue on the red ... never noticed that before. Just get a pack of springs at Advance Auto off the "Help Line" aisle, experiment. You want something that pulls it shut but doesn't cause fatigue on a drive.
Old Mar 4, 2023 | 06:43 PM
Jadesupercab
ok ill give it a shot. Worse come to worse I could always double or get a double spring if what I get dont fit
Old Mar 4, 2023 | 08:11 PM
tbear853's Avatar
tbear853
I like at least one spring in front to better balance the load on the throttle shaft (steel) going through the carburetor base (aluminum or zinc) ... partly why I keep the red one. Another reason for two, I've had one break while driving a school bus, so I've known for 50+ years that it happens.
Old Mar 4, 2023 | 08:19 PM
Jadesupercab
yes leave the rear spring but double up the secondary bracket spring if I cant find one with more pressure than the rear one like you said the red one is stronger than the blue.
LARIAT 85
Jul 30, 2010 09:17 AM
pdqford
Apr 5, 2009 12:57 PM
Christopher2
19
Jan 15, 2005 10:04 PM
Christopher2
Dec 27, 2004 10:19 AM
