Throttle Return Spring
Old Jul 29, 2010 | 09:46 AM
LARIAT 85's Avatar
LARIAT 85
Do the 1980 - 1986 carbureted trucks use a separate throttle return spring? My 1985 302 truck doesn't have one, and it hasn't for the past 10 years.
My stock throttle cable itself has a spring on it, but that is the only one. Should there be another for throttle return?
Old Jul 29, 2010 | 06:03 PM
Old Hickory's Avatar
Old Hickory
Are you having any problem that you know of that might call for for more spring? If not
I wouldn't worry about it. My 1981 has about the same throttle cable as your 1985 and
with a 4180 Holley on it I did add a light spring to make sure it would always return to
idle when I let off the throttle.
Old Jul 29, 2010 | 06:36 PM
LARIAT 85's Avatar
LARIAT 85
No, I haven't had any problems with it as it is.
I just noticed almost all the older carbureted vehicles in the junkyards use a smaller return spring, and was wondering if this is something I should have or need to put on. There was a lot of missing components taken off my truck before I took ownership, and I would like to get it correct. I currently don't drive my truck all that much, but I am getting it more and more ready for daily use, and I want to be sure I am not leaving off something important!
Old Jul 30, 2010 | 04:55 AM
Old Hickory
If I remember correctly, my truck was completely stock when I got it as it had been
purchased new by my Dad. It had a stock 302 with AOD and I don't think it had a
separate throttle return spring but relied on the cable spring to control the throttle
return. I'm not sure that that would be exactly like your 85 but should be similar.
Old Jul 30, 2010 | 09:10 AM
1986F150six's Avatar
1986F150six
LARIAT 85,
My son and I own a 1984 and 1986 F150 with 4.9L engines. Both are stock and neither has a return spring attached to the carburetor..
Old Jul 30, 2010 | 09:17 AM
LARIAT 85's Avatar
LARIAT 85
Thank you gentlemen!
tommyduncan
18
Apr 5, 2019 04:50 PM
BIDIL
Nov 7, 2016 09:21 PM
WARDNEAL
May 7, 2012 09:00 PM
77300i6
1997 - 2003 F150
Jul 4, 2011 09:21 PM
Brads-idi
Apr 7, 2011 10:40 PM
