Throttle Return Spring
Old Dec 23, 2004 | 08:10 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Anybody have a picture of the correct setup for a throttle return spring for a 1950 Ford with a 226 flathead 6 cylinder? I did some looking today and the only spring acting as return spring is the accelerator spring. This is not returning the truck to idle when the accelator is released even with the linkage off the carb. I have a DSl connection so a 2-3mb file is fine no need to edit the picture unless you want to.
Old Dec 26, 2004 | 01:45 PM
Christopher2
Veteran: Navy
Nobody here knows?
What is supposed to return the truck to idle? Is the spring in the accelerator pump supposed to do the this?
Old Dec 27, 2004 | 06:29 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Can't help you on the specifics of the '50 but the carburetor throttle shaft springs (or the accelerator pump spring) are never the sole source of return. The pedal and/or the linkage always have their own return spring.
NHRA requires 2 springs outside the carburetor, too.
Old Dec 27, 2004 | 07:04 AM
Christopher2
Veteran: Navy
I think there should be more than one also. I would have thought the people that go 100% stock would have been able to answer this.
Old Dec 27, 2004 | 08:20 AM
mich52's Avatar
mich52
Mine is a V8, but there is a spring going toward the front of the engine on mine, attached to the generator bracket. Probably not stock, but I am going to leave it. Where is your other heater core outlet? Mine are one above the other on the firewall. Maybe different for a six?
Tom
Old Dec 27, 2004 | 10:19 AM
Christopher2
Veteran: Navy
billslk32
Mar 5, 2014 03:27 AM
Mike Mckenna
Apr 7, 2012 12:55 PM
Dag L
May 31, 2011 05:03 AM
Brads-idi
Apr 7, 2011 10:40 PM
marty68
Oct 15, 2005 08:02 PM
