2004 F350
Old Jul 21, 2012 | 06:18 PM
gscoull's Avatar
gscoull
2004 F350
I have had an egr bypass done on a 2004 F350 6.0 diesel. Since then, the oil stays very clear. Any ideas why the oil is staying so clear? Even after 3,000 miles, the oil is still clear.
Old Jul 21, 2012 | 11:54 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jul 22, 2012 | 12:19 AM
BLADE35's Avatar
BLADE35
Well with a EGR deleate you are putting Less Soot back into the Cylinders
Soot will work its way by the rings and then into the Oil
most change oil every 5K
Some go 7.5K but no More
The oil shears in the 6.0L so viscosity goes thinner
At 5K some of the Oil reports come back at a 30w well Ford will run 10-30w so if thats good for them I run my oil till 7.5K
But you also have to watchout for Fuel Delution
Old Jul 22, 2012 | 08:17 AM
gscoull's Avatar
gscoull
Thanks for your reply - do you ever run Lucas through your motor?
Old Jul 22, 2012 | 08:23 AM
bismic's Avatar
bismic
What oil are you using?
I absolutely do not recommend Lucas oil additive - it is not needed and IMO can cause issues.
Old Jul 22, 2012 | 10:03 AM
gscoull's Avatar
gscoull
I'm using Shell Rotella oil
Old Jul 22, 2012 | 10:06 AM
gscoull's Avatar
gscoull
using Shell Rotella 15/40
Fefanatic
Feb 5, 2018 03:12 PM
Skiptomylucky
Jul 30, 2011 09:24 PM
fordnut74
Bio-diesel, Propane & Alternative Diesel Engine Fuels
19
Apr 9, 2005 10:12 AM
bad ass diesel
Nov 5, 2004 06:05 AM
redfir
Jan 21, 2004 08:36 AM
