Oil
Old Jul 30, 2011 | 02:03 PM
Skiptomylucky's Avatar
Skiptomylucky
Oil
Can anyone answer this for me. I just hade number 7 injector replace on my 2007 F350 and I had my oil and filter changed a week before it was replaced with Shell synthetic and I just check my oil and it's very dark!! do you think I should change it.
Old Jul 30, 2011 | 02:22 PM
bismic's Avatar
bismic
Diesel oil is supposed to remove and suspend soot.
I assume the shell oil you used is a diesel rated oil (CI4+ or CJ4 rated)?
Old Jul 30, 2011 | 02:23 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You are driving a diesel.....today's oils have cleaners in them....I'd worry if it DIDN'T get dark!
Old Jul 30, 2011 | 02:27 PM
BLADE35's Avatar
BLADE35
how long has it been miles
theres always 2 maybe 3 quarts of oil that stay into the oil system when its changed HPOP reservoir , oil cooler ect....
Old Jul 30, 2011 | 02:28 PM
Skiptomylucky
My oil never did get black by the time it was for a change. I use ames or mobil 1 . this the first time I used shell
Old Jul 30, 2011 | 02:38 PM
bismic's Avatar
bismic
Once again :
I assume the oil you used is a diesel rated oil (CI4+ or CJ4)?
Old Jul 30, 2011 | 05:32 PM
Skiptomylucky
Yes it a CJ4 grade from Shell, they say it the best !! however when I use Ames or Mobil 1 after 10,000km it is still clear. So should I change it just after having number 7 injector replaced and my fuel pump.
Old Jul 30, 2011 | 05:34 PM
Skiptomylucky
Cj4 was used with shell 5/40 synthetic
Old Jul 30, 2011 | 05:48 PM
bismic's Avatar
bismic
Rotella T6 is a great oil. I know nothing about Ames ?? Mobil 1 makes a good diesel oil also - the Turbo Diesel Truck oil.
They should all get pretty dark quickly.
Old Jul 30, 2011 | 05:54 PM
Skiptomylucky
Originally Posted by bismic
Rotella T6 is a great oil. I know nothing about Ames ?? Mobil 1 makes a good diesel oil also - the Turbo Truck and Diesel oil.
Thank for your help, I feel better now, I was going to change it. Now I wont, however will change it at 5000 Km's from now instead of 10,000KM.
Old Jul 30, 2011 | 09:24 PM
mnmwhit's Avatar
mnmwhit
my oil doesm't get real black in 5000 miles. really just dark enough to see it on the stick
microdevil45
52
Jul 21, 2015 10:44 PM
ford 5ver
Oil & Lubrication
Mar 6, 2009 08:37 AM
Futuresweets-10
13
Feb 5, 2009 04:22 PM
jkh04200
May 3, 2007 11:15 PM
fordnut74
Bio-diesel, Propane & Alternative Diesel Engine Fuels
19
Apr 9, 2005 10:12 AM
