2007 f-250 6.o driving down the road truck just stop runing trun key nothing engine will not spin put two new battery and starter still no start check all fuse all ok went trun key all you can hear is clk clk at the fuse box no sound under hood all gauge work window and door lock work can some one help and no reading at DTC
First off, welcome to FTE; hate you've found us because your having issues with your truck.
You've got fuses under the steering column and under the hood (ahead of the brake master cylinder)....so I'd check/double check both areas before moving on. And you may have to use a DVM (digital volt meter) to make sure the fusees are good. I had one of the ones for the gauge cluster pop and was only able to find it by using a DVM. After that, I'd work through this "no start" thread.
A bad fan clutch or shorted wiring to the fan clutch (or broken wire) will keep it from cranking. Unplug the fan clutch and see if it'll crank. If unplugging the fan clutch doesn't help, then try this: Locate the wire to the starter solenoid (yellow with light blue striped colored wire adjacent to the passenger side battery in the engine compartment, near the vacuum pump - it has a "squeeze-and-pull" type connection) ..... you can unplug it and get it to reach the positive battery terminal and try to start it that way.
(thanks Mark (Bismic))
