Off To The Dealership Monday
Old Jul 20, 2012 | 04:29 PM
tjustice's Avatar
tjustice
I have been beat, still no start ,,,, Cranked off and on most all day and nothing..My numbers are IPC 1370 to 1440, IPC 31 to 70s, FICM 49.5, battery anywhere from 12.4 to 11 when quit cranking....Guess will mess with it till Monday then trailer her to Dealer........
Old Jul 20, 2012 | 05:56 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Are you moving fuel?
Old Jul 20, 2012 | 06:48 PM
BLADE35's Avatar
BLADE35
First that^^^^^^^^^^^^^^^^
Then check to see if you are getting FPW=Fuel Pulse Width this will verify the FICM turning on
Then check CKP/CMP Sync
Then check FICM Sync
Old Jul 20, 2012 | 06:49 PM
_Me2_'s Avatar
_Me2_
sling blade - YouTube
Old Jul 20, 2012 | 08:18 PM
tjustice's Avatar
tjustice
Well she started, finally...... Took her out for a drive, no leaks.... How many qts of oil since she was dry????? put 17 in her so far not showing on dipstick......
Old Jul 20, 2012 | 10:06 PM
bismic's Avatar
bismic
18 qts or thereabouts
Old Jul 20, 2012 | 10:12 PM
BLADE35's Avatar
BLADE35
Oh did you change your Oil Cooler or something???
I thought the Truck was Just a No Start
Old Jul 21, 2012 | 06:26 AM
tjustice's Avatar
tjustice
Sorry Blade35, yes originally was pulling truck just died...towed to dealer, they said a list of things and priced at $11k to fix. I towed home, pulled cab off and did new head studs, gaskets, new head,injector orings,injector,oil cooler,water pump,HPOP,blue spring,transmission service,new filter, replaced most gaskets and I think that is all....
Old Jul 21, 2012 | 06:31 AM
wulfman's Avatar
wulfman
So T dealer wanted 11k how much did you save doing it yourself ?
Ferguson65
All Things Towing
21
May 17, 2015 11:13 PM
dr cabela
Jul 18, 2012 08:43 PM
quiacato
Mar 8, 2011 11:23 AM
billnuke1
All Things Towing
15
Jun 1, 2009 01:11 PM
BigD_ca
2004 - 2008 F150
Sep 7, 2006 07:41 PM
