Tachometer problem
Old Jul 18, 2012 | 02:39 PM
Lil Red Sled's Avatar
Lil Red Sled
Tachometer problem
My rpm gauge hasn't worked since I bought the truck. (85 f250 6.9). The tach sensor wires were showing so I replaced the sensor. Now the rpms will go up but will not come back down. Haven't had a chance to dig deep yet. Just seein if anyone had a similar issue?
Old Jul 18, 2012 | 05:25 PM
David85's Avatar
David85
I almost wonder if the shaft in the tach assembly itself is sticky from years of not moving.
Mine will not read above 2500 and sometimes sticks there if I take the engine much higher then that. In my case however I suspect an internal electrical fault with the tach itself. I'm not sure if its fixable and didn't have time to troubleshoot the PCB on the back of it.
Old Jul 18, 2012 | 07:02 PM
Lil Red Sled
Il follow the wires and make sure they are all Ok. I have found alotta half *** stuff done to this truck already
Old Aug 27, 2012 | 07:26 AM
Dieselamour's Avatar
Dieselamour
anyone have a diaphram (diagram)?
Old Aug 27, 2012 | 09:30 AM
Lil Red Sled
What wiring diagram do you need. What's the year of your truck ?
Old Sep 3, 2012 | 07:23 AM
Dieselamour
1986 F350. My gage started working again after driving it for a while.
Here is the diagram link:
https://www.ford-trucks.com/forums/1...in-wiring.html
matt1288
Jul 26, 2015 11:48 AM
andrew1
Mar 7, 2011 08:50 PM
rum runner
Mar 17, 2010 02:09 PM
rmalottwtes30
Dec 2, 2008 10:23 PM
