Engine cutting out
Old Jul 23, 2015 | 12:39 PM
matt1288's Avatar
matt1288
Engine cutting out
Tach works when first cranked up. Tach works going down the road until you let off pedel then it falls to zero until you push pedel again. Sometimes going highway speed tach falls back for just a second and engine cuts out for a second. Any suggestions
Old Jul 23, 2015 | 09:42 PM
Chevy_Eater's Avatar
Chevy_Eater
The only way an IDI could cut out electrically is if the power to the FSS is interrupted. So your tach problem coupled with the cut out would lead me to check connections and ignition switch.
Old Jul 24, 2015 | 12:59 AM
Macrobb's Avatar
Macrobb
Sounds like wiring to me too.
Old Jul 26, 2015 | 11:48 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Check the wires and connector comming out of the tach sensor.
Located on the IP drive gear housing.
Cracked insulation on the tach sensor wires let moisture and oil into the sensor, which means it is about to die.
Look right where the wires come out of the sensor for cracks in the insulation.
texas7816
Aug 24, 2015 12:28 PM
Case IH Guy
18
Mar 16, 2012 07:33 PM
rum runner
Mar 17, 2010 02:09 PM
jqp00002
Apr 6, 2005 12:01 AM
