Trans cooler line splicing help please!
Old Jul 22, 2012 | 11:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
i don't have any trucks here with any of those fittings at the moment.
double flair is what brake lines have. the adapter screws on the end of the line, and the other end has a hose barb on it. then i just slip the line on and hose clamp it. sometimes i have to make the fitting out of 3 pieces but it is still not more than about $4 for all 3 pieces of brass
yes, it is basically what you posted, only it is brass instead of stainless steel, and female on the pipe end instead of male threads
Old Jul 22, 2012 | 11:28 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Got it, I went to the Napa website. I couldn't find exactly what I am looking for there, but maybe I'll just drive over there and see what we can put together. Believe it or not, I live in the concrete wasteland that is the L.A. basin, and the nearest Napa is 15 miles away!
Thanks,
Mac.
Old Jul 22, 2012 | 11:38 AM
tjc transport
i ain't rite
sometimes you will have to get the flair end fitting, the pipe barb fitting, and then a coupler to connect them. either pipe dope or teflon tape on the threads before you put it together and you will be good to go.
Old Jul 22, 2012 | 11:55 AM
akamacgyver
Clueless spectator!
I'll drive over there tomorrow.
I'll post results.
Gotta work on the 93 today, need to get her ready to sell
Thanks again,
Mac.
Old Jul 22, 2012 | 05:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
thats gunna be the hard part.wrenching is easy next to that im sure.
too bad you couldn't keep 'em both,but maintaining one (as you know) is a chore enough hey Mac? lol.
Old Jul 22, 2012 | 05:46 PM
akamacgyver
Clueless spectator!
Code:
No doubt!
Yeah, also a 2WD truck is basically useless about 6 months of the year in Denver. (especially one with a 1300 lb motor sitting over the front wheels!) I'll do a lot better trying to sell it here in CA. It'll make someone a good tow rig. When I get her all ready, I'll throw up a post to see what you all think I should ask for her. I have decided not to swap any parts at all. It was hard to hit the Ford dealer to drop another 72 bucks on a tach. sensor when I had a brand new one just sitting there, but she's a runner, I want to keep her that way. I just took her to AZ 350 miles across the 115* desert A/C blazing the whole way, with no problems at all.
Old Jul 24, 2012 | 09:36 PM
akamacgyver
Clueless spectator!
I picked up these today, I think they will work sweet!
It is a 5/16 compression to female 1/4" NPT with a 1/4" NPT male to barbed fitting
I was hoping for flared fittings, but I am sure they will work fine. I got both 5/16" and 3/8" barbed fittings for different size tube, and will use the Oetiker clamps. GOODBYE LEAKS!
Old Jul 25, 2012 | 06:33 PM
airdale94's Avatar
airdale94
I think the screw type clamps you are talking about are fuel injection hose clamps.
http://www.amazon.com/Fuel-Injection.../dp/B0040CRRW8
I'm pretty sure you can put a female fitting on a steel line then flare the line.
Old Jul 25, 2012 | 08:32 PM
akamacgyver
Clueless spectator!
You can if you use a fitting like in the beginning of the post,
http://api.viglink.com/api/click?for...13432663816792
but I had a hard time finding the nut for them, if you look at the specs, it says it has a 1/2" 16 thread, and a standard nut is a 1/2 20 thread. I called the company because I thought it was a typo, most of those parts use standards, but they said it was correct. I didn't want to end up with a bunch of fittings I could not use, and they could not provide me with a compatible nut, so I decided to go with the compression fittings they will work as well, but won't look as good. Oh well.
tractormanbill
May 26, 2014 07:22 PM
J ballan
1997 - 2003 F150
Feb 14, 2013 07:38 AM
Watcher
Mar 29, 2005 10:25 PM
Jerrod
Jul 24, 2004 04:51 PM
JoeBlow
Apr 10, 2003 08:14 AM
