Ok, some dummy (we won't point fingers here) took the transmission lines off and failed to notice which line connected to which hose coming out of the cooler. There is a line in the back of the transmission and one in the front. Then there is a hose on the driver's side and another on the passenger's side of the cooler. Now the dum. . .ah I need to know which line connects to which hose.
What year and type of vehicle F or E series......with or without extra cooler please do a signature.
Front trans line is outlet goes to LH side of rad, rad RH side goes to cooler then to rear inlet line, No cooler rad to rear trans line.
Sorry. Its a 1992 F350 2WD 7.3L Dl
I don't see an extra cooler. All I see are the one for the AC and the radiator. I'll try to describe the hose set up on the radiator. From driver side to passenger side there is a large hose going th the engine, then a small hose for the tranny. A foot or so from that there is another small hose for the tranny and next to it is a medium size hose which appears to go to the heater.
L = large hose going to engine
M = medium hose going to heater
s = small hose for transmission
<driver side> L s s M <passenger side>
Reason: forgot to add more info
OK so your only worried about the two small 5/16" ID hoses since you appear to have not OEM extra trans cooler. Front line to LH and rear line to RH. The Large hose is coolant return to engine and the medium is an ATF fluid internal rad heater/cooler line.
