Garrett turbo high flow outlet ????
Old 07-18-2012, 11:55 AM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Hey guys - I will be installing a high flow outlet & eliminating my stock ebpv - What happens to the sensor after I do this - Will I need to remove it or leave as is ? Tia, Bill
Old 07-18-2012, 12:14 PM
F250_'s Avatar
F250_
F250_ is offline
Somewhere in here is an EBPV delete writeup, and I'll see if I can locate it and post it up for you. From what I recall, you can unplug it but it will throw a soft code. One of the aftermarket guys makes a plug you can install in the sensor harness that eliminates the soft code, but I believe it is just a plug with a commonly available resistor connecting the two wires out of the plug to fool the PCM into thinking that the EBPV is functioning, and you can actually make your own plug for little to nothing.
Like I said... I'll snoop a bit and post what I can find for you.
EDIT/UPDATE:
Thread discussing the issue in greater details... https://www.ford-trucks.com/forums/1...-question.html
Another good read... https://www.ford-trucks.com/forums/8...v-removal.html
Aftermarket EBPV Code eliminator - prefabbed... http://www.puredieselpower.com/catal...tor-p-106.html
Hope this gives you everything you need.
Old 07-18-2012, 12:59 PM
guitarpicr's Avatar
guitarpicr
Hey Pete - Thanks much for the links !
Old 07-18-2012, 04:58 PM
rockinxj's Avatar
rockinxj
rockinxj is offline
High flow outlet
I recently installed a 1.15 outlet with no ebpv and I am lovin it.
I have an edge programmer with three settings. I can run the 40 hp tow all day long with no EGT worries. Spooling is slow but once it gets the rpms up its pretty much WOT all day with no worries. I have run the 80 HP tune some and it really gets the job done but its not to be ignored cause the EGTs can get up there pretty quick.
I may be a little lazy but I like using my cruise.
I am pulling 20 to 26 thousand pounds with a 9500 pound F-550 so it gets a workout.
Be interested in hearing how it works out for you.
Old 07-18-2012, 05:02 PM
rockinxj's Avatar
rockinxj
rockinxj is offline
And to help with the question. I just left the wire hangin and gutted the pedestal. it sets a code but doesnt turn on the light. (soft code)
Old 07-18-2012, 06:54 PM
guitarpicr's Avatar
guitarpicr
Thanks - I'll let you know how it does when I get it installed & get a chance to tow. Still waiting for some cooler weather to get 3 or 4 mods done-
DCook909
04-15-2013 11:19 AM
santacruzf250
12-02-2012 03:03 PM
60RatRod
16
06-16-2010 01:32 PM
F250_
01-07-2010 09:48 AM
QFD90
16
04-07-2005 08:45 PM
Quick Reply: Garrett turbo high flow outlet ????
