Y block with headers - which spark plug wires?
Old Jul 17, 2012 | 01:56 PM
Mikulh's Avatar
Mikulh
This is a question for you guys that are running headers on your y-blocks.
What spark plug wires are you using? I need to find some that have an angled spark plug boot(either 45 or 90 degrees) to keep them off the headers, but I'm not having much luck other than the $150 ones... and that's not happening.
I don't know why a set of SBF cut-to-fit spark plug wires wouldn't work as long as they were for a distributor cap with female contacts.... but summit doesn't list them as working for a 292.
thanks,
Michael
Old Jul 17, 2012 | 03:12 PM
63' f100's Avatar
63' f100
I just got the cut to fit ones at an auto store. I can't tell you which brand or anything, but they worked ok. I screwed up on one of them, so one of my spark plugs has the old wire on it.
Old Jul 17, 2012 | 03:56 PM
charliemccraney's Avatar
charliemccraney
Any stock replacement plug wires should work. If you're running an aftermarket ignition and need fancier wires, 8mm will fit the stock wire brackets. A wire much bigger and you'll need to come up with some other solution.
I've used universal 8mm Pertronix wires in the past with homemade brackets. Now I have 12mm Performance Distributors wires in homemade brackets. In both cases they more or less follow the stock routing.
Mocked up on a spare engine:
And in the truck.
Old Jul 17, 2012 | 04:10 PM
Mikulh's Avatar
Mikulh
Thanks guys... that's what I was really hoping to hear (that the universal, cut-to-fit wires would work).
I really like they way those look Charlie. Mine doesn't even have any of the brackets anymore... looks like I will need to find some of those as well.
Old Jul 17, 2012 | 10:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Carpenter has the spark plug wire separators, look on page 68 of his 1957/66 truck repro parts catalogs for the different types.
Old Jul 18, 2012 | 09:42 AM
Mikulh's Avatar
Mikulh
Thanks ND!
52 USCG Panel
Mar 25, 2017 03:30 PM
ExtrmZ
Jul 22, 2011 07:59 PM
cbass139
Jul 21, 2009 11:16 AM
MYTRUCK
Apr 20, 2009 08:59 PM
conchstew
May 10, 2008 09:41 AM
