5th wheel to GN
Old Jul 16, 2012 | 11:27 AM
adbscu's Avatar
adbscu
5th wheel to GN
My In-laws just got a new heathland Elkridge (30fT). They have a SD as well with at true 5th wheel. We might want to move short distance the rig with our truck that has a B&w turnover ball for our GN horse trailer.
Should we go for a B&W companion hitch($800+) or an adapter for the actual trailer to make it GN friendly?
My biggest problem woUld be storing the new piece at my place. I think the max we would tow it would be 400mls ( San Francisco to San Diego or viceversa) maybe 1 time a year
Thanks
Old Jul 16, 2012 | 12:08 PM
bpounds's Avatar
bpounds
Is your truck a long bed? Or is the trailer contoured so that it won't be a problem with a short bed?
Gooseneck adapters are hard on fiver frames. I wouldn't let someone borrow my fiver using an adapter. The manufacturers usually won't honor a warranty if the adapter has been used. An exception is the new Reese/Lippert air cushioned adapter, but I think it costs as much as a Companion. At least Lippert gives their blessing to use it.
Old Jul 16, 2012 | 12:58 PM
RV_Tech's Avatar
RV_Tech
Although I am not a big fan of goosenecking RV, it sounds like that application will be pretty limited. one a year San Diego to SF, so I would be more likely to go with a gooseneck adapter.
Old Jul 16, 2012 | 05:40 PM
senix's Avatar
senix
Once a year turns into twice or three times a year. make the investment in the hitch.
Old Jul 16, 2012 | 05:48 PM
P.Bronner's Avatar
P.Bronner
The Reese product mentioned above is called the Goose Box and is a replacement for the original pinbox, not just an adapter so it would be a bit of a job swapping it out each time you wanted to tow that trailer. If it were me, I'd go with the Companion because it gives you more versatility with your truck and the money is just about a push.
Old Jul 16, 2012 | 05:54 PM
bpounds's Avatar
bpounds
Good point about it being a replacement, and I had forgot that. The inlaws might not appreciate having their pinbox disassembled every time you want to use their trailer. Also, that Goosebox isn't going to be any smaller or lighter to store.
Old Jul 16, 2012 | 06:05 PM
P.Bronner's Avatar
P.Bronner
Of course there is always the option of getting the in-laws to put a GN in their truck. Then the trailer could be converted to the Goose Box and nobody has to lug/store a fifth wheel hitch. I have seriously considered this for my trailer but have not acted on it yet.
Old Jul 16, 2012 | 07:51 PM
DIYiT's Avatar
DIYiT
I'd say go with the Companion hitch. It's what I use with my 5ver. I stored it on the pin box of the camper. I put a few ratchet straps around the base of the companion hitch looped to the pin box itself to support the weight so that the rubber bushings wouldn't have to support the base.
Old Jul 16, 2012 | 10:08 PM
Ford_Six's Avatar
Ford_Six
You can get Companions online for $700 or so. I have seen them used in the $400 range.
dvw20748
2009 - 2014 F150
36
Nov 3, 2012 09:50 AM
jmmartin
All Things Towing
Mar 25, 2009 05:15 PM
George D.
All Things Towing
Mar 21, 2008 08:06 AM
mhoefer
All Things Towing
27
Apr 17, 2006 10:10 PM
stan_02ranger
All Things Towing
Feb 15, 2005 06:05 PM
