trailer adapters
Old Mar 23, 2009 | 09:53 PM
jmmartin's Avatar
jmmartin
trailer adapters
Is there a gooseneck to fifth wheel adaptor? i know there are adapters to go from a kingpin to a goose ball, but can you go the other way? i have a 15k 5er for the bed already.
Old Mar 24, 2009 | 06:49 AM
mistakenID's Avatar
mistakenID
I know if you think about it for a minute you will see the trouble. Gooseneck is long enough to reach almost to the bed of the truck. 5th wheel hitch is usually already above the wheel wells.
Bout all you can do is shorten the gooseneck and weld on a kingpin.
Old Mar 24, 2009 | 11:18 AM
jmmartin's Avatar
jmmartin
most of the trailers im my neck of the woods have the adj gooseneck on them thats why i am curious about it
Old Mar 24, 2009 | 08:26 PM
grafekie's Avatar
grafekie
Yes, you can buy adaptors at your local trailor shop. They are quite pricy.
Old Mar 25, 2009 | 02:44 AM
John970's Avatar
John970
Goose Neck too King Pin
I'm confused (and that didn't take much)! If the trailer is set up with a Goose Neck, it is basically set up to run 2' 5/16 over the surface of the bed. Well most King Pin/5th wheel trailers the hitch point is 12" to 18" OVER the bed surface. So if I were TRY'ing to change from Goose Neck to King Pin I am raising the front of the trailer 9" to 15" and that alone will cause TOWING issues.
So who what hitch will say they reduce the hitching point to jive with normal towing position(s)? Where or how would an adaptor bring that down?
I know that BW does and I think there is an options for Reese to add a Ball Mount (Goose Neck) to your existing RAIL Mount King Pin mount.
If you read my past posts you'll find that I am a STRONG supporter of the Goose Neck connection for what it is worth.
Old Mar 25, 2009 | 03:54 PM
FordxFour's Avatar
FordxFour
If you have an adjustable tube hitch, call the builder to see if they offer a 5th wheel tube to replace the goose neck tube. I know Big Tex and PJ do, as I have both tubes for my trailers. The PJ 5th wheel tube was $175.00 and the Big Tex was about $225.00.
Old Mar 25, 2009 | 05:15 PM
believer45's Avatar
believer45
HERE is one for a round tube with set bolts
THIS ONE is for a round tube with pins to secure it
PUTNAM makes one for square tube as well
I love google.
Dave / Believer45
ford2go
General Automotive Discussion
Apr 24, 2014 12:41 PM
rpatrick
Jun 8, 2011 07:19 AM
hunt3r
Electrical Systems/Wiring
May 5, 2010 03:41 PM
larryejoh
1966 - 1977 Early Broncos
May 2, 2008 02:28 PM
repou
Offroad & 4x4
Jan 19, 2007 11:22 AM
