Refrigerator problems !!!
Old Jul 15, 2012 | 10:23 PM
jdadamsjr's Avatar
jdadamsjr
didn't cool for two days and finally figured it out....
the 2 large bottles COULDN'T be out of propane I said...
but still blinking LP light means "I ain't got no propane" !
so demount both off the 5er,
drag them to the fill place, and the old guy picks one up and says this'ns full !
and dis one is only down say 3 or for gallun I'd say
so I say let's button them up anyway since they are out...
go back to the new rv and as I reach down to pick up that heavy thing, I noticed WAY up in the top of the cavity is the three way regulator/switch that I had been looking for in this new rig
guess before I just happened to turn on the correct bottle as the switch had a right, left, and center position and was turned to the right
My simple brain thought run only one and then when it runs out,
turn on the other bottle and go fill up only one at a time...
but guess I need to figure out what either of the three positions really do...
presume middle is both bottles, right is one, and left is the other.... just need to trace the lines to see which it goes to...
Old Jul 16, 2012 | 04:13 AM
RV_Tech's Avatar
RV_Tech
With a standard regulator, putting the switch in the middle shuts off the tanks, or should. Right or left designates tank you are drawing from and should switch automatically when one tank runs out. Here's a link
http://www.newrver.com/propaneregulator.shtm
Steve
Old Jul 16, 2012 | 08:05 AM
jdadamsjr's Avatar
jdadamsjr
Thanks for the quick reply - reps your way (if I'm allowed to thank you anymore )
Sorry for the rookie questions as it's been a LONG time since I had my last rv ! (I had downsized to a winnebago LeSharo from class A'a 20 years ago iirc)
your link must be behind a firewall or something as I can't get to it...
but here are some (bad) pics of my 'switch':
to the right is how I found it...
and didn't notice which tank it goes to yet...
is the red on the top a reset or an indicator of some type ?
I guess I should only have the bottle valve open that the dial points to, correct ?
then when that runs out, I switch over..
Someone told me this:
You can tell the level of propane in a tank by pouting warm water down the side of the tank. Feel it and the propane level is where the tank changes from warm to cool.
Old Jul 16, 2012 | 09:30 AM
RV_Tech's Avatar
RV_Tech
No firewall. I receive quite a few questions every day and write about the stuff I work on. Nothing for sale on site. No ads. Mobility RV Service or MOBILITYRVSERVICE.NET.
Steve
Old Jul 16, 2012 | 09:32 AM
jdadamsjr's Avatar
jdadamsjr
I bet u do get a lot of questions !!! You b smart
just an fyi, got page not found when accessing this link
will review your other 'stuff' as I want to learn thanks !
Old Jul 16, 2012 | 09:38 AM
RV_Tech's Avatar
RV_Tech
Not smart, just old!
Steve
Old Jul 16, 2012 | 09:42 AM
RV_Tech's Avatar
RV_Tech
Geez, I should have caught that. I can write HTML.
It should look like this Understanding your propane regulator
And yeah, the hot water trick works. The inside monitor seldom are accurate. You can keep one tank closed or leave em both open. If you have em both open and it switches to the second tank and you don't realize it, you can find yourself without propane.
Sorry,
Steve
Old Jul 16, 2012 | 11:02 AM
jdadamsjr's Avatar
jdadamsjr
Steve
I like to think of it as experienced
thanks again Steve - the link splains it well !
Open invitation anytime you are in the dfw area !!!
And we'll be @ Maumelle in Little Rock in Oct - so come on by and meet the merry band of 5 or 6 rv's that get together regularlly
Old Jul 17, 2012 | 02:31 PM
senix's Avatar
senix
I use just one tank at a time mostly so that I know when it is out..unless it is cold outside that is.
newandoldford250
30
May 9, 2014 05:54 AM
texanrick
Jan 16, 2012 05:46 PM
peanutpalomino
Aug 11, 2010 03:25 PM
Kikko
Jul 25, 2003 01:55 PM
rickkerby
Jan 12, 2003 12:03 AM
