Help..
Old Jul 12, 2012 | 10:45 PM
mblack14's Avatar
mblack14
Help..
I have a 2000 ex with the 05 frount end. My headlight on the right side stopped working I have the high just no low. I replaced it and still no go. Has this happen to any one? P.S I suck at wiring so please when you answer make it were I would know what to look for..
Old Jul 13, 2012 | 01:09 AM
archtaan's Avatar
archtaan
Did you check the fuse under the steering wheel area. There are 2 different fuses for the low beam/high beam. Not sure what the number is for a 2000 but it will be in your owner manual.
If it isn't that and you changed the bulb it is likely a wire. There are only 3 so it is not to hard to trace. One is high, one is low and one is ground.
Old Jul 13, 2012 | 03:00 AM
Monsta's Avatar
Monsta
Sit. Stay.
Who did your 05 front end conversion?
Old Jul 13, 2012 | 06:07 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
See if this thread helps: https://www.ford-trucks.com/forums/1...t-problem.html
ChrisSpanos
Dec 25, 2018 01:15 AM
2006powerstroke90
Dec 31, 2010 09:32 AM
riggz
May 13, 2009 11:18 PM
akford351
Jan 7, 2006 10:30 PM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
