Sponsored by: Auxito
Headlight problem
Old Jan 30, 2005 | 05:25 AM
lon371's Avatar
lon371
Headlight problem
2000 F-150, have low beam, when you activate high beams the indicator comes on and headlights go off. Any suggestions. thanks
Old Jan 30, 2005 | 06:59 AM
kingfish51's Avatar
kingfish51
Are you sure the high beam filament is not burned out. These bulbs have 2 filaments, one for low beam and 1 for high beam. If high beam filament is out, when you hit the high beams the headlight will go out.
Old Jan 30, 2005 | 11:21 AM
jseim44's Avatar
jseim44
Ion371,
you may want to check your fuses, i believe their is a fuse for your high beams, i think with if burned out your indicator will still come on. good luck, hopo you get it fixed
